how to install rear springThis is a discussion on how to install rear spring within the Misc Riding Types forum, part of the Specialty Riding Forums category; i just got an applied racing rear spring and when i try to install it the directions say to loosen ... |
| i just got an applied racing rear spring and when i try to install it the directions say to loosen the 14mm nut and i do it then what? the eyebolt still wont come out. anyone have any ideas? |
The eyelet is not supost to come off, you need to look at the ring at on one end of the shock it will have a groove/cut out in it. when you back off the preload rings you should be able to slide the spring retainer off the shock shaft, change the spring & reinstall the retainer & readjust the preload. |
| if your talkin about a xr/crf50 the directions are right. loosen the nut and the eye bolt should spin should thread off. mine did no problem |
| subscribed |
| Rear spring | Freak | Motorcycle Suspension Tuning | 3 | 08-29-2007 04:32 PM |
| Rear Shock Spring | 3 stroke | 2-Stroke Motorcycles - General Discussion | 8 | 08-17-2005 06:05 AM |
| spring for rear shock | xrycrivellox | Motorcycle Suspension Tuning | 3 | 03-14-2005 11:48 PM |
| Replacing Rear Spring..... | Spitfire | Motorcycle Suspension Tuning | 4 | 03-10-2004 07:48 PM |
| Rear spring...I am a bit stumped. | zoohoot393 | Motorcycle Suspension Tuning | 23 | 01-02-2004 05:46 PM |
