Go Back   All Things Moto! Web Forums > Reviews - Organized Rides - Recreation Areas - Classifieds > Product Reviews > Drivetrain, Tires & Suspension
Chain Stretch Tester?
This is a discussion on Chain Stretch Tester? within the Drivetrain, Tires & Suspension forum, part of the Product Reviews category; Have not tried it, but for $14, it seems like a good buy for an accurate and quick stretch limit ...
Old 08-10-2005, 08:17 AM
pragmatic393's Avatar
..Thats, Mr. Spode to you!
Last Online: 11-12-2009 01:21 PM
Default Chain Stretch Tester?
Have not tried it, but for $14, it seems like a good buy for an accurate and quick stretch limit test. Whatta ya think?
Old 08-10-2005, 08:18 AM
Satch0922's Avatar
Default Re: Chain Stretch Tester?
that is interesting....
Old 08-10-2005, 10:06 AM
Thumprding's Avatar
Last Online: 01-09-2007 07:36 AM
Hmm interesting, but normally I wear a set of sprockets out before I wear the chain out. As such I am changing chains before they are "stretched" out.
Old 08-10-2005, 12:31 PM
FFRacing11x's Avatar
The "ONLY" FastForward
The easiest way to tell if your chain is beyond limits is to grab it at the 3 o'clock position on the rear sprocket and pull directly back. If you can pull it back far enough to see the "valley" between the teeth, it's time to replace. Tdub
Old 08-10-2005, 01:03 PM
I like the pull and peek method. Used to be so into gadgets of anykind. Now I have so many that I can use a time tested method (such as Tryce's) faster than I can find my "test gadget" and then retrain myself to use it.
Old 08-22-2005, 10:54 PM
Jaybird's Avatar
Last Online: 10-27-2007 11:15 AM
If you wear out a set of sprockets, the chain is worn out.
It is the elongation of the chain pitch that wears out the sprockets. If the chain is still within safe running specs, then there is an adjustment problem.
Sprockets DO NOT wear before the chain elongates, unless there is a bad adjustment or you are using a gooey lube and riding in sand dunes.
Most folks who see sprockets wearing first have the chain too tight. Every jump is ruining the chain drive, CS, and wheel bearings.
Old 08-07-2009, 02:59 PM
Last Online: 08-07-2009 02:59 PM
I think you can also measure 12 (or so) links, and compare to what that distance should be for a 520 chain (for instance) when new. If 1.5% greater distance used than new, its time to replace. Some people say 3%, I`m not sure which is right, for a cheapskate like my I`d go 3%.
Similar Threads for: Chain Stretch Tester?
Chain Stretch roostertail6 ATV/UTV - Yamaha 3 03-30-2008 08:56 PM
I know this is a stretch, but I thought I'd try cowboyona426 General Discussion 22 12-20-2007 07:58 PM
compression tester 89 cr250r 2-Stroke Motorcycles - Honda 3 09-12-2007 01:06 PM
leak tester Yamadog 2-Stroke Motorcycles - General Discussion 0 01-04-2005 01:39 AM
Best long lasting anti-stretch chain? 2fun General Discussion 53 04-30-2004 07:02 PM
