Go Back   All Things Moto! Dirtbike Forums > Dirt Bike - ATV - Suspension Forums > ATV/UTV Forums > ATV/UTV - Suzuki
Old 03-26-2017, 01:26 PM
Last Online: 03-29-2017 03:37 PM
Default Suzuki LTA50 - Urgent Help
Please please please can someone help me before I go mad or worse take a large hammer to oyr much loved LTA50.
Last year she was running OK, little sluggish but OK. Winter came along and I decided to do a rebuild on it, all OEM parts.
- New head
- Piston
- Cylinder
- New Exhaust (has a small hole in the old one)
- New Spark Plug
- Gaskets etc
- Full carb clean out
- New filter
- and all new high quality fluids
OK.............3 days on and SHE WILL NOT START. I can not work out why
- Carb appears OK, set to manufactuers spec. only difference is its fully clean
- Plug is sparking perfectly
I pull and pull and pull and pull.................pull again and still it will not fire.
Am I missing something, please help I'm lost
Old 03-27-2017, 07:48 AM
Last Online: Today 06:00 AM
It sounds like you are not getting fuel into the engine.
Try starter fluid to see if it will fire up. If it fires up ( will die quickly) then you do have a fuel delivery problem.
Old 03-28-2017, 09:08 PM
Last Online: 06-20-2019 05:00 PM
Any luck is it getting fuel and spark never had a spark issue with the alt50 trike we have but the carb does get plugged easy if it sits to long doesn't take much to block those small holes
Old 03-29-2017, 03:10 PM
Thank you all sorry for the delay been reading/playing/trying.
---------- Post added at 09:56 PM ---------- Previous post was at 09:55 PM ----------
Yes have a good spark, brand new plug
---------- Post added at 09:56 PM ---------- Previous post was at 09:56 PM ----------
Compression test also done today
---------- Post added at 09:58 PM ---------- Previous post was at 09:56 PM ----------
Along with a lot of hair pulling
---------- Post added at 10:10 PM ---------- Previous post was at 09:58 PM ----------
I'm so lost with WHY this will not start.
- High quality plug and getting a great spark no probs, even tried tiny bit of fuel in the top the end to help it on it way, nothing.
- Just done a compression test, getting just over 5 kg/cm2, pretty good.
- Fuel is also going into the carb......not sure if its getting into the engine or not. I dod not a small amount of fuel in the air filter box
Something to note, I now you will know the answers, I hope.
I have the LTA50 around 2002. The head it was originally fitted with was like this http://images.esellerpro.com/2757/I/...4012-0F0_B.jpg - if has the brass niple on with a black pipe on (not sure where this went to or what it was for)
The new cylinder I was given by the dealer was like this http://partdiscounter.com/media/cata...nder-kit-7.jpg - with no nipple
What is this for?? where should it be connected? manual does not say and the guy in shop said dont worry its a breather, not really needed
Also, there are two connects on the fuel swtich/fuel cock - manual says one is fuel other is a breather. Does the breather need to be connected to anything?
http://cdn.partzilla.com/product/oem...9ad46cabf5.jpg
Any help all will be a life saver.
Old 03-29-2017, 03:40 PM
Last Online: Yesterday 04:16 PM
If you do a search on this forum, I know the topic has been brought up before. I can't recall exactly what the extra tube or line to the head was for, but it was a known issue on the LT50 that others have bypassed.
---------- Post added at 02:40 PM ---------- Previous post was at 02:38 PM ----------
Try this link- 86 LT50 mystery problems, need help
Old 03-29-2017, 08:46 PM
Maybe its me but your links didn't work here's a pic of my 83 alt50 the line goes from the head goes to the fuel petcock Its not on the head but right before on the intake
---------- Post added at 06:41 PM ---------- Previous post was at 06:32 PM ----------
Hers a few more shots
---------- Post added at 06:46 PM ---------- Previous post was at 06:41 PM ----------
I have a shop manual somewhere I can dig up if you want if it has spark and getting fuel she should fire I've never played with timing on these my lt250 has some adjustment do these have any
Old 03-29-2017, 08:49 PM
Again...Try it with "starter fluid" sprayed into the intake and see if it will fire. If it will fire then you know for sure the engine is not getting fuel to the engine.
If I recall correctly there are 2 positions on the fuel petcock. One for starting and one for running. I seem to further recall that they had to use the engine vacuum to get the fuel to start flowing, then when running it would flow correctly if in the run position.
I am concerned that the mismatched parts may be the route cause for the starting issue.
Old 03-30-2017, 11:51 AM
Has it even tried to run with fuel or starting fluid ? From what I read in my shop book it does not look like there's any adjustment with the timing here's a few pics of the stator and mag. Also some info on the vacuum for the petcock and carb rebuild.
---------- Post added at 09:45 AM ---------- Previous post was at 09:44 AM ----------
---------- Post added at 09:49 AM ---------- Previous post was at 09:45 AM ----------
---------- Post added at 09:51 AM ---------- Previous post was at 09:49 AM ----------
Old 05-09-2017, 11:03 PM
Last Online: 05-09-2017 11:06 PM
Similar Threads for: Suzuki LTA50 - Urgent Help
03 LTA50 peaceflood ATV/UTV - Suzuki 3 05-13-2013 08:55 PM
suzuki lta50 will not start brianflewellen General Discussion 1 04-30-2011 12:06 PM
LTA50 will not start - help addictivetoyz ATV/UTV - Suzuki 6 11-08-2010 02:23 PM
Lt50 or LTA50 Float level jrandsu ATV/UTV - Suzuki 0 12-04-2009 03:49 PM
2002 Suzuki LTA50 kids quad Matt Fisher Classified Ads 0 04-28-2004 09:46 PM
