Suzuki LT50 Quad - DErestrictingThis is a discussion on Suzuki LT50 Quad - DErestricting within the ATV/UTV - Suzuki forum, part of the ATV/UTV Forums category; Hi there, just bought a little LT50 quad for the little ones & found it a bit on the under ... |
| Hi there, just bought a little LT50 quad for the little ones & found it a bit on the under powered side for them, just wanted to know if someone out there could tell me how i go around de restricting/unrestricting the engine so i can get some xtra power/torque from it. I look forward to hearing from you, thanx a lot. |
| If you already have all the baffles out (intake and exhaust) then you're looking at doing some real work to make it better. The stock port timing is very conservative and somewhat mismatched. The cylinder needed to be cleaned up so it was bored 0.040" and the corresponding piston fitted. I also ended up taking 0.055" off of the top of the cylinder, used a 0.040" base gasket and raised/widened the exhaust port to work with the new timing of the transfers for a peak around 6000 rpm. The clutch shoes were lightened for a higher engagement RPM and I went one tooth larger on the front sprocket. It moves pretty good now. |
| Thanx for the reply m8, much appreciated, not had any baffles out yet, could u take me throu the 1st step of derestricting the motor tho, would really appreciate it, look 4ward to hear from u again, cheers. |
| Is it a 2 stroke or a 4 stroke |
| 2 STROKE |
1) Pull off the carb and look in the intake. Some models have a washer with a hole in the middle in there to act as a restrictor plate. Use a screw driver and gently pry it out. 2) Pull the exhaust and look in there as well. Look for yet another restrictor plate and use a screw driver and gently pry it out. 3) Take the float bowl off the carb and look for the pilot jet. They use stacked pilot jets meaning that there are two intsalled. Take out the first one and leave the second one in there. Thats about it. Last edited by Faded; 06-21-2008 at 01:20 PM. |
| Hi, may i thankyou very much for taking the time to post this reply to my question about the DE restricting of my LT50 quad, i will do my best to undertake the work as you adviced, your advice is much appreciated, thanx again. |
| It wouldn't be worth it...the air filter won't make a noticable difference and the stock motor won't hardly pull gearing taller than stock. |
I'll look into shaving the head and we've got and extra clutch to experiment with and porting it. |
| Read carefully, it's not just shaving the head. You can get aftermarket pipes if you can find them, but you'll spend a lot and only gain a little. Milling the top of the cylinder and modding the exhaust port made a huge difference on the one I worked on. |
| Where did you get the spacer for the bottom of the cylinder? What had to be done to the exhaust port to gain the most power? How about the intake port? |
| How to de-restrict Suzuki LT50 quad | mtk | ATV/UTV - Suzuki | 33 | 02-22-2010 06:17 PM |
| 1994 lt50 quad please help | daver1 | 2-Stroke Motorcycles - Suzuki | 21 | 02-15-2009 06:15 PM |
| SUZUKI LT50 2 STROKE QUAD, NOT RUNNING RIGHT??????? | holstenpills | ATV/UTV - Suzuki | 4 | 01-14-2009 01:10 PM |
| Suzuki 50 Quad Help | charity_rider | ATV/UTV - Suzuki | 9 | 09-07-2007 12:52 PM |
| Suzuki Quad-4WD Only $900.00 | ccra92 | Motorcycles & ATV's | 1 | 07-19-2006 07:11 PM |
