Go Back   All Things Moto! Dirtbike Forums > Dirt Bike - ATV - Suspension Forums > ATV/UTV Forums > ATV/UTV - Suzuki
Old 08-28-2006, 08:40 PM
Last Online: 08-31-2006 08:29 PM
Default Suzuki 50 Quad Help
I am helping a friend of mine. His sons towed this 2003 Quad 50 around with out the engine running and now it acts as if it is stuck in gear. I removed the clutch (centrifical) and there is nothing broke. I put it all back together and tighten the clutch nut just past finger tight and it locks the clutch up meaning it acts as if the clutch has engaged to drive the back wheels. The recommended torque on the nut is 62ft lbs and I cant even get close to that before it locks up. I verified the clutch and component installation with the factory drawing. Can anybody out there help me on this. Thanks.
Old 08-28-2006, 11:11 PM
2fun's Avatar
Last Online: 02-06-2018 12:12 AM
Default Re: Suzuki 50 Quad Help
1st off, welcome to the forums!
2nd, what kind of quad is it? 2-stroke? 4-stroke?
Was there plenty of oil in the tranny??
I'm no expert on transmissions, but perhaps with a little more info, someone here can shed some light on the problem!
Old 08-28-2006, 11:33 PM
Tdub's Avatar
You might want to double check on that Tq spec...I could be wrong, but that seems quite high. They are usually in the mid 40# range. Tdub
Old 08-29-2006, 06:32 PM
Thanks. This unit is an oil injected 2 stroke 2003 model. There was enough oil in the tranny. The torque specification is right from the service manual, but I can't even get 10ft lbs on it before it locks up.
Old 08-27-2007, 10:54 AM
Last Online: 03-01-2008 11:30 AM
I suspect your clutch drum is seized to the bushing due to lack of lube. It gets oil from the injection pump. When you take the drum off the cranck there sould be a bushing in the center that spins freely. Press it out, polish it up so it goes back in and spins freely. You can tell it is seized if the drum does not spin by hand with enging off. The hub nut must be tight or it will spin off and jam on the case. When you get the drum off you will see the bushing. It need the oil from the pump. Mike
Old 09-02-2007, 11:03 AM
2fun's Avatar
WOW!
Nice info!!
Old 09-05-2007, 05:25 AM
Hi. I have done a little more work on my 84 lt50. I dont think the drum bushing is in fact lubed by the injector pump but by the engine oil for the gearbox, which must be kept up to the level hole below the fill plug.
My bike has the injection pump disconnected and tank is missing so thats why I thought that had causd the bushing to seize. There are lots of people running without the injuector pump so it must be ok.
Mine has had a tank of gas through it since I polished up the bushing and refilled the oil sump, the clutch is working ok, so I will haul it apart and check out the bushing again.
Questions: What type of oil is supposed to be in the gearbox?
What type of oil and what ratio are people mixing when injector pump is not being used?
Thanks.
Old 09-05-2007, 06:24 AM
triplendo's Avatar
Last Online: 03-31-2017 12:26 PM
The injection pump needs to be hooked up for several important parts to get lubed. If yours is inop thats probably the problem. I would give more specific info if I could remember it but its been 20 plus years since I worked on Suzuki's for a living. But I do know that the injection oil is critical to other parts other than the top end. The engines on the 50's have been the same since about 1977 or 78. I hope this helps.
Old 09-05-2007, 09:20 AM
Faded's Avatar
You are correct, the clutch assy. is lubed by the trans case oil. The 'recommended' oil is probably 10W30 or 10W40 but gets along fine with ATF Type F which is what I use.
With stock porting this engine only turns 3k, maybe 4k RPM's...a premix ratio with less oil, say 40:1 or even 50:1 is probably sufficient.
I oversee an '84 that's ported with head mods and no injection pump running 32:1 with ATF Type F in the trans and it's been going all summer without any problems.
Old 09-07-2007, 12:52 PM
2fun's Avatar
Nice info Faded!!
Good to see you on the boards!!
Similar Threads for: Suzuki 50 Quad Help
How to de-restrict Suzuki LT50 quad mtk ATV/UTV - Suzuki 35 06-25-2013 07:15 PM
Suzuki LT50 Quad - DErestricting holstenpills ATV/UTV - Suzuki 12 04-26-2010 03:06 PM
SUZUKI LT50 2 STROKE QUAD, NOT RUNNING RIGHT??????? holstenpills ATV/UTV - Suzuki 4 01-14-2009 01:10 PM
Suzuki Quad-4WD Only $900.00 ccra92 Classified Ads 1 07-19-2006 07:11 PM
New quad for suzuki? quadrider32 ATV/UTV - Suzuki 6 07-29-2003 11:56 PM
