Go Back   All Things Moto! Dirtbike Forums > Dirt Bike - ATV - Suspension Forums > ATV/UTV Forums > ATV/UTV - Suzuki
Old 01-09-2009, 05:47 PM
Last Online: 01-22-2009 08:51 PM
Default LTA50 will not start - help
First of all, thank you for all your help in all these forums. This is the first time I have posted a question becuase every answer is usually out there.
I have a 2004 LTA50 that will not start. I bought it this way thinking that it has to be easy to fix. I replaced the carb, the top end with a new piston and rings, machined the head .020", and replaced the spark plug. All fuel and vent lines are new as well. The restrictor is out of the intake and exhaust. I removed the first pilot jet and installed a 75 main jet as per many threads here.
I cannot get it to even try to run. I have lots of spark and have tested the generator and coil as per the service manual and they is all within specs for voltage and resistance. I have tried carb cleaner directly in the spark plug hole and nothing. I have tried it without the exhaust thinking maybe there is some restriction, and still nothing.
I pulled the flywheel and the key in the crank to the rotor is still good and in place.
I have great compression (thanks to the milling), great spark, and carb cleaner still won't make it hit a lick. I have eliminated the carb by using the carb cleaner in the SP hole and am just amazed. I have never seen a two stroke do this, ever!!
Please help and give me some other areas to check. There isn't that much to go wrong, I didn't think.
Thanks in advance for your help.
James
Old 01-10-2009, 06:54 PM
2fun's Avatar
Last Online: 02-06-2018 12:12 AM
That is really wierd..........
I know you said you checked the flywheel key, but are you sure the timing isn't off somehow?
All you need is spark, good fuel, correct air/fuel mixture, compression, and timing.
Never tried carb cleaner in the sparkplug hole before. I have always used starting fluid. I would assume however, that either one would work?
Can you keep your finger sealed against the sparkplug hole when cranking it over?
Old 01-10-2009, 07:03 PM
The compression is really good. It blows your finger right off. I took this site's advice and milled 0.020" off the head to help increase compression.
I don't know any other way the timing could be off, but maybe someone here has some ideas.
Old 01-10-2009, 07:11 PM
2fun's Avatar
Boy, I am really at a loss here.....
Sounds like you've checked everything...
Hopefully someone else can stop by and lend a hand. I'm kinda out of suggestions at this point.
However, seeing this is your first post, welcome to ATM!
Old 01-10-2009, 07:12 PM
2fun's Avatar
Maybe try putting it all back together, and pull it behind another ATV to see if it will fire up??
Old 02-25-2009, 04:13 PM
Last Online: 04-06-2009 05:36 PM
Default lt 50
I have a lt 50 with the same exact problem it will fire on starting fluid sprayed into the cylinder thru the open exhaust port or thru the spark plug hole but not thru the carb I have done everything you have with no luck did you get yours running if so what was the problem ????????
Old 11-08-2010, 02:23 PM
Last Online: 11-16-2010 03:00 PM
Hey addictivetoyz! Did you ever figure this problem out? I have the same problem and have been tearing my hair out.
Similar Threads for: LTA50 will not start - help
Won't Kick Start But Will Bump Start RoostRM125 2-Stroke Dirt Bike Forums 38 02-22-2008 05:06 PM
Cant start my kx 250 buck12point2009 2-Stroke Dirt Bikes - Kawasaki 4 09-10-2007 06:30 AM
Why won't it start? Oring 4-Stroke Dirt Bikes - Yamaha 1 08-17-2005 07:07 AM
2002 Suzuki LTA50 kids quad Matt Fisher Classified Ads 0 04-28-2004 09:46 PM
426 start up. overlord 4-Stroke Dirt Bikes - Yamaha 9 02-18-2004 09:33 PM
