Go Back   All Things Moto! Dirtbike Forums > Dirt Bike - ATV - Suspension Forums > ATV/UTV Forums > ATV/UTV - Suzuki
Old 11-03-2018, 03:20 AM
Last Online: 01-30-2019 12:28 PM
Default LT50 - Newbie Problem
Hi team,
Have recently purchased a LT50 2000, not running but assured it Ďit would be fineí.... Iíve got minimal experience on bikes and none on LT50ís.
I replaced the plug and gave it a new tank of gas, this allowed it to start but ran on half choke and not idling well.
So I stripped the bard down and cleaned out the jets with a wire brush strand. Putting it back together the bike will only start with the choke on and then dies and wonít start at all with the choke off.
Looking at the plug it is wet/dark and can be wiped down but guess this means too much fuel into the engine?
To add to the scenario the tank has a little rust in it and the gasket between the carb and engine is split in two (needs to be replaced soon).
Iím assuming the rust could be causing issues for the carb however the petcock filter still looks good enough.
Iím scratching my head as to what to look at next and any help would be appreciated.
Cheers
Old 11-03-2018, 06:39 AM
Last Online: Today 08:46 PM
The split carb boot may be making it too lean to start.
Old 11-03-2018, 12:35 PM
Thanks Paw Paw will get that done this morning and report back.
Old 11-03-2018, 07:23 PM
Right, got the gasket sorted with some gasket paper and got it as about as good as I could.
It ended up starting and then dying, same old.
With the airfilter off I placed my hand over the air intake and it fired up, no for long but off choke and ran for a while longer than previously with the choke on.
I tried this again however noticed a bit of petrol on my hand I.e appeared to be getting too much fuel.
Took the carb off and undid the bowl to adjust the float cut off. I bent the metal tab that triggers the cut fuel cut off up so the float didn’t have to get so high before stopping flow.
(Previous day I had tested the float simply by removing the bowl, leaving the fuel line attached to the carb and seeing if the fuel would stop as I moved the float up and down - it worked, however not to say it does when operating under normal conditions).
I put it all back together and it started up, no choke, and it ran, however it seemed to be reving a bit high/not what id deam an idle. It ran for say 5 seconds and then died.
Tried starting it again however no joy. I then checked the plug to find it wet again (cleaned it at the start of the day).
I looked down the carb from the air filter to check the needle seating in the jet, it appears ok to my untrained eye, moves freely in and out.
From the above, restricting airflow seemed to work, so does this mean too much petrol is getting into the carb? And therefore the needle possibly isn’t seating correctly?
Am I also right in assuming the jets must be clear if too much fuel is getting in?
Thanks
Old 11-03-2018, 07:46 PM
The jets have nothing to do with the fuel flow to the carb, but rather the fuel flow to the engine. The reverse flow of fuel onto your had is normal as this does not have a reed valve.
Sounds like you may still have an air leak and a fuel supply issue.
Old 11-03-2018, 07:55 PM
Thank you will relook at the bowl and see where else the air could be getting it.
Old 11-04-2018, 01:36 AM
Had a couple of goes writing this reply as the phone died.
Went back, and looked around for any air leaks that jump out to me, tightened up the bolt that clamps the carb to the elbow leading to the head, but only slightly.
Tried starting again, no luck.
So checked the bowl and dumped fuel out of there but no fuel came out, so undid the carb for the ?th time today to adjust the float, did this a few times until got fuel running out of the drain plug for the carb.
Then the better half came out, still didn’t start after multiple attempts.
Better half left, not encouraged by my progress.
So I thought about the air, and covered the air filter with my hand and it started. Revved up and then died as I took my hand off the airfilter. So I tried it again and left my hand on the filter for a while longer and low and behold back into life.
Took my hand off and as it started to die I half covered it and away it went.
I left it running for a bit on the jack and altered the throttle screw bringing the revs down a bit.
I left it running, revving it a little for a couple of minutes. I then stopped it and easily started it again with no hand on the filter. So got my daughter to have a go around the backyard and was able to restart it easily.
However I left it a couple of hours and it was back to being stubborn.
Not starting at all.
So I dumped the fuel from the carb, out it on prime briefly and then back to run, it would fire but not run
Eventually I put a rag over the air filter as couldn’t get my hand on it due to the plastics, stuffed it as tightly as I could and it started.....
It ran for a bit then died so I did the same again and away it went. I had no time to keep playing with it however getting an idea that blocking the airfilter to start it works until it’s warm, then once warm we are away.
I can’t put my finger on why it’s apparently working when starving the airfilter.
Does this allude to an air leak somewhere still?
Daughter loved it when it was going, the dog not so much, ohh well.
Cheers
Old 11-04-2018, 07:01 AM
It still sounds like an air leak to me. When you place the rag or had over the air filter you are starving the engine of air and thus makes the mixture rich, as needed for cold running.
You may want to totally clean the carb using a carb soak.
Old 11-04-2018, 11:38 AM
Thanks Paw Paw, I'll strip it down and give it a good soak.
Cheers
Old 11-06-2018, 02:37 AM
Very wuickly, I stripped down the carb completely, taking off the choke component and the rubber seals. I got a can of carb cleaner and basically emptied it into a container deep enough for the carb to sit and submerge the area the main jet sits and the central cylinder of the carb (sorry technical words escape me) as there was a bit of crap in there. Also took apart all the jets for them to soak.
I let it sit over night and took a toothbrush to it, cleaning out the main cylinder.
It was hard to start for a couple of times then I again blocked the airfilter but it was a lot easier than previously to start.
I turned it off and restarted, again easier.
I’ll report back in 24hours, leaving it a day and seeing how it is.
My wife’s sceptical of the results...
Similar Threads for: LT50 - Newbie Problem
2001 lt50 steering problem chrisf1 ATV/UTV - Suzuki 0 06-11-2014 12:26 PM
2008 LT50 Problem mpsteil ATV/UTV - Suzuki 0 08-22-2010 12:30 PM
lt50 problem screaming2stroke ATV/UTV - Suzuki 3 07-20-2010 07:37 AM
LT50 dsalt13 ATV/UTV - Suzuki 0 06-03-2010 10:03 PM
Newbie with a carb problem CPL593H 2-Stroke Dirt Bike Forums 11 12-13-2007 02:34 PM
