baffleThis is a discussion on baffle within the ATV/UTV - Suzuki forum, part of the ATV/UTV Forums category; i was wonderin if any one knew if taking the baffle out of a 2004 suzuki ltz 250 would hirt ... |
| i was wonderin if any one knew if taking the baffle out of a 2004 suzuki ltz 250 would hirt it becuse it seams to run better with out it. |
| No it would not hurt it. You may need to rejet since you will get better air flow which usually causes a lean condition, but as long as you do that you should be fine. |
| What elevation are you at? It will not hurt it to remove the baffle as stated. If you are at a higher elevation, that is probably why it runs a little better with the baffle out because you are leaning it out a little and most bikes come jetted for sea level. |
| ya i live at about sea level i live in mout pearl nfld wich is about 200feet above sea level |
| Then I would rejet if I were you. |
| so would I. At least change air screw and move your needle one clip down. |
| cool thanks ill give that a try |
| what is a baffle | klxrider3214 | 4-Stroke Motorcycles - Kawasaki | 3 | 08-11-2005 11:44 AM |
| removing baffle | Vinny3299 | ATV/UTV - Yamaha | 1 | 07-14-2005 10:57 PM |
| Cant get my Baffle off | quadrider32 | ATV/UTV - Yamaha | 8 | 05-31-2005 11:51 PM |
| Pulled Baffle off 04' Raptor | roadrash | ATV/UTV - Yamaha | 6 | 12-30-2003 05:05 AM |
| how do take off the baffle and jet the the carbuerator | 04'yfz4u | ATV/UTV - Yamaha | 14 | 11-14-2003 04:05 PM |
