All Things Moto! Web Forums
Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > ATV/UTV Forums > ATV/UTV - Suzuki
1985 suzuki LT 50 running hot
This is a discussion on 1985 suzuki LT 50 running hot within the ATV/UTV - Suzuki forum, part of the ATV/UTV Forums category; Hi everyone I just got a 1985 suzuki Lt 50 its missing a bunch of things and im piecing it ...
Old 07-17-2009, 09:22 PM
Last Online: 07-18-2009 03:33 PM
Default 1985 suzuki LT 50 running hot
and im piecing it back together I took a compression test and Im only get 45 psi it is how ever missing the air cleaner so i dont know if that has a lot to do with it or not it starts real easy bout 3rd pull first if it sets for a little I cleaned the carb changed the oil and plug but it seems to run hot and bogs when you go to wined it out kinda like the plug is fouled I took the plug out and its clean also i removed the plastic restrictor in the carb I guess what my question is, is that does it seem like the top end needs re built? my gas ratio is 2 1/2 oz to 1 gallon of gas
Old 10-06-2009, 04:47 PM
SuperX's Avatar
Last Online: 10-13-2009 12:49 PM
Well, from what I've learned so far, I'm pretty sure your compression should be up around 100psi. Mine was doing the same thing (aaround 44psi) until I put a new piston & rings in it, then it started right up 1st pull. Now I just can't keep it running longer than 20-30 minutes. Still trying to figure that one out. I hope that helps!
Similar Threads for: 1985 suzuki LT 50 running hot
SUZUKI LT50 2 STROKE QUAD, NOT RUNNING RIGHT??????? holstenpills ATV/UTV - Suzuki 4 01-14-2009 02:10 PM
1985 250 e Suzuki canloon 4-Stroke Motorcycles - Suzuki 1 04-28-2005 11:33 AM
1985 cr250, should i do the top end? CheM 2-Stroke Motorcycles - Honda 6 03-01-2005 09:31 PM
1985 Suzuki 125?? Woody_YZF ATV/UTV - Suzuki 5 08-22-2004 01:38 PM
Restored 1985 atc 70 42F67N Motorcycles & ATV's 0 04-19-2004 07:06 PM
