Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > ATV/UTV Forums > ATV/UTV - Kawasaki
Bayou 220 choke ineffective
This is a discussion on Bayou 220 choke ineffective within the ATV/UTV - Kawasaki forum, part of the ATV/UTV Forums category; I have a 1992 Bayou 220, it is very difficult to start when cold, the choke seems to do nothing ...
Old 04-11-2007, 03:01 PM
Last Online: 04-13-2007 07:13 PM
Default Bayou 220 choke ineffective
I have a 1992 Bayou 220, it is very difficult to start when cold, the choke seems to do nothing at best or make it harder to start. After it is started the choke kills the engine rather than helps it maintain idle. The manual states there is no adjust for the choke. Is there a jet or soemthing? Thanks in advance for suggestions
Old 04-11-2007, 06:06 PM
mxmama393's Avatar
Niffer
Last Online: 11-03-2009 10:45 PM
Default Re: Bayou 220 choke ineffective
Hey we have that same 4 wheeler!! maybe a yr or so later model. Been through some very ROUGH moments, and one of or dogs ate the seat off of it, but we fixed that. Still runs perfect!! Its a dark teal blue, I didn't think anyone else had one! lol
I probably cant help with your choke issue, but I do know a VERY similar problem was going on with my hubby's Honda foreman, and it turned out he had to replace the choke cable.
Last edited by mxmama393; 04-11-2007 at 06:29 PM. Reason: LOL changed "clutch" to "choke" Sorry!
Old 04-11-2007, 06:23 PM
Last Online: 07-17-2009 08:33 AM
She means CHOKE cable.
If your bike is running and the you choke it and it dies then that is not abnormal. If its warmed up and you choke it all the way it could kill it.
Is the bike wanting to die and feels like its not warmed up? You need to give more detail. You could have a bad choke cable. You need to unscrew it from your carb and see how it functions when you pull the choke knob.
I assume you have a remote mounted choke lever ont he handlebar.
Old 04-11-2007, 06:35 PM
When the bike starts up, but is still not warmed up, it kills the engine. Please expand on "bad choke cable", the cable operates the choke plunger. My understanding is the cable is usually okay or broken, since there is no adjustment. However, I am still open for suggestions. And if I still have not given enough info, please let me know- I'll try again.
THANKs!
Old 04-11-2007, 06:37 PM
Make sure your filter is in good shape. That last time I wne to clean the filter on our 97 bayou the filter was lieterally falling apart. will you r bike run well once its warmed up? If not and you choke cable isn't stuck then you may need a carb rebuild. It is 15 years old and I don't know what its been through.
Also,make usre you have a good plug - a weak plug will have a yellow spark and will want to die when ever you give it more fuel.
Old 04-11-2007, 06:44 PM
you're right- I needed to give more info- the bike runs real well when warmed up, I did rebuild the carb, it was gummed up real bad and wouldn't even start when I got it from the farmer that had it sitting under his tree.The filter and plug are near new. When I rebuilt the carb I do not remember anything being installed or replaced regarding the choke. Is any of that helpful for more ideas. Thanks again
Old 04-11-2007, 09:17 PM
If it runs well when warmed up then nothing is wrong with the carb. Sounds like a choke issue. Try to diagnos whether or not it is moving up and down in the carb like it should. Look to see of the cable is sticking or separated any where. Make sure the slide at the end of the cable (part that goes in the carb) is in correctly. I know on my foreman it had grooves and had to be put in one way.
Old 04-11-2007, 09:21 PM
One more thing to look for. On my honda the choke cable sleeve came apart where it attached to the knob. The bike woud run fine but I had choke problems likeyou have until I finallly to the cable off and looked at it. There has to be something keeping the plunger from sliding like it should.
Old 04-11-2007, 09:42 PM
Thanks- Logic makes me feel it is right there somewhere- I'll take it apart and take a close look again- closer or longer this time. Thanks
Old 08-18-2007, 12:51 AM
weld_13's Avatar
headline here
Last Online: 08-04-2009 03:08 PM
I have the exact same model not same year but same problem! It was like that once I bought and never figured it out it has good filter,plug, & runs good once warmed up. Whats funny is no matter who I meet I'm the only one who knows how that thing trully works and how to get in its week spots. I have never figured the choke out think it is just a bad carb setup in the first place I guess but I'm clueless
Similar Threads for: Bayou 220 choke ineffective
220 bayou dave171 ATV/UTV - General Discussion 4 01-27-2008 07:45 PM
my bayou dixienw123 ATV/UTV - General Discussion 5 02-08-2005 12:07 AM
220 bayou Macho393 Wanted Items 1 12-19-2004 09:33 PM
My bayou CR Chick 2-Stroke Motorcycles - Honda 4 03-25-2004 08:30 PM
Kawasaki Bayou 220 Tuktuk08 Motorcycles & ATV's 0 10-05-2003 10:55 AM
