650 prairie diff lock cable adjustmentThis is a discussion on 650 prairie diff lock cable adjustment within the ATV/UTV - Kawasaki forum, part of the ATV/UTV Forums category; Ok so I had to remove the Differential and overhaul it due to the spider gears seizing on the cross ... |
| Ok so I had to remove the Differential and overhaul it due to the spider gears seizing on the cross pin. Now I can not seem to get the Diff lock cable on the arm and or adjusted up correctly. right now it is 2 teeth off of the dot on the splines just to get the cable onth the arm. Any Ideas would be helpful |
| Clutch Cable Adjustment? | ahighland | General Discussion | 6 | 02-02-2009 02:18 PM |
| Honda Recon 250 Diff Air tight or not? | kkilloy | ATV/UTV - Honda | 3 | 01-12-2009 11:01 AM |
| 91 trx 300 4x4 rear diff | pealage | ATV/UTV - Honda | 0 | 03-16-2008 10:07 AM |
| clutch cable adjustment | p.e.z. | 2-Stroke Motorcycles - Yamaha | 6 | 05-11-2007 06:18 PM |
| hotcams for xr400 wat's the diff? | dsmndspencer | 4-Stroke Motorcycles - Honda | 6 | 10-03-2005 11:37 PM |
