trx250r clutch problem?This is a discussion on trx250r clutch problem? within the ATV/UTV - Honda forum, part of the ATV/UTV Forums category; hey, i have a 1986 trx250r and the problem is that (eather cold or hot) when i let the clutch ... |
| hey, i have a 1986 trx250r and the problem is that (eather cold or hot) when i let the clutch lever about half way the clutch starts to make this grinding noise. The oil level is up, i dont think it is the trany b/c its only when im leaving, and the when im leaving it dont feel like the clutch is wore. So does anyone have any ideas what might be making this noise? Any info owould help Thanks |
| Sounds to me like its your clutch fibers. May be time for a new clutch. I know of a great up-grade you can do. Let me know if you want it and I'll send you the link. |
Why not post up the link for everyone to see?? Tdub |
| Yep, Neils mod works great. I have also found out that you can use the pancake bearing and rod for a 89 clutch and use the 86 preasure plate by using all 400ex steels. The thicker steel plates take up the space that the 86 pressure plate leaves. The thicker steels grab harder and disipate heat better than the thinner 250r steels. Last edited by fulltiltrider; 07-30-2009 at 10:54 AM. |
| Clutch problem | mbogosia | 2-Stroke Motorcycles - General Discussion | 13 | 08-20-2007 03:14 PM |
| clutch problem?? | kxracer521 | 2-Stroke Motorcycles - General Discussion | 0 | 06-27-2007 05:14 PM |
| clutch or not?? PROBLEM help thx | Cr125zrule | 2-Stroke Motorcycles - KTM | 10 | 06-01-2006 04:29 PM |
| clutch problem 250 (01) | scotsguy | 2-Stroke Motorcycles - Honda | 7 | 04-26-2004 12:32 PM |
| Clutch Problem | YzRacer#53 | General Discussion | 7 | 12-17-2003 07:32 PM |
