Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > ATV/UTV Forums > ATV/UTV - Honda
Honda Recon 250 Diff Air tight or not?
This is a discussion on Honda Recon 250 Diff Air tight or not? within the ATV/UTV - Honda forum, part of the ATV/UTV Forums category; I have the differential out of my 2002 Recon 250. I was cleaning the inside and noticed the cleaning fluid ...
Old 01-10-2009, 06:36 PM
Last Online: 01-16-2009 10:32 PM
Default Honda Recon 250 Diff Air tight or not?
I have the differential out of my 2002 Recon 250. I was cleaning the inside and noticed the cleaning fluid will come out where the drive shaft connects when the unit is leaned foward. The other seals don't leak. When the diff is installed on the atv the drive shaft end is above level, so no leaking. Is the unit suppose to be airtight, or do I need to replace the seals?
Thanks,
Kevin
Old 01-10-2009, 07:44 PM
2fun's Avatar
Super Sonic Moderator
Last Online: 02-27-2010 03:57 AM
Thanks,
Kevin
I am not 100% on this, but I would assume there should be no leakage from that area. OBviously there will be times when you are going down steep embankments, which would cause that area to be below level (if I'm reading your post correctly). Do the seals look worn at all??
Also, the cleaning fluid you are using is probably a lot thinner that the differential fluid that is normally in there.
Therefore, it is possible that the cleaning fluid may leak while the thicker differential fluid will not. Just something to think about.
Oh, and I see this is your first post, so I'd like to say welcome to ATM!
Old 01-10-2009, 10:06 PM
After further inspection I realized that the differential was only leaking when removed from the ATV because the drive shaft was not installed, which is where the sealing take place. Sorry, my fault, should have looked closer.
Thanks,
Kevin
Old 01-12-2009, 11:01 AM
2fun's Avatar
Glad to hear you got it all figured out!
Similar Threads for: Honda Recon 250 Diff Air tight or not?
2001 honda recon jordan_pense ATV/UTV - Honda 3 03-20-2008 09:24 PM
91 trx 300 4x4 rear diff pealage ATV/UTV - Honda 0 03-16-2008 10:07 AM
hotcams for xr400 wat's the diff? dsmndspencer 4-Stroke Motorcycles - Honda 6 10-03-2005 11:37 PM
04-05 HONDA ATV's RECALLED Foreman, Rincon, Rancher, Recon SirFallsALot243 ATV/UTV - Honda 5 05-11-2005 10:52 PM
WR250 or XR250 $1000 diff. icemanrulz 4-Stroke Motorcycles - General Discussion 22 03-18-2004 06:43 PM
