Go Back   All Things Moto! Dirtbike Forums > Dirt Bike - ATV - Suspension Forums > ATV/UTV Forums > ATV/UTV - Honda
Old 07-04-2003, 03:40 PM
Last Online: 08-27-2003 09:55 AM
Question '99 Foreman TRX450ES (Electric Shift) Problem
Hi,
I have a '99 foreman TRX450ES (electric Shift)
It's been a pain in the #$$ lately. I'll tell you why
I had someone try and break into the key with a screwdriver.
Since then, the Key switch does not work and I can't get any life out of the ATV. I did put in a new Key Switch (OEM Part# 35100-HNO-A02) but still no life. But I do get life when I hotwire the old key switch by connecting the red, pink and Black wires and leaving the Red with black stripe out.
Why won't the new Key Switch work? Maybe the Control Module was damaged and the wires it recognizes changed? Anyway, I either have a wrong part number from the microfiches of three different suppliers. Or I have something beyond my knowledge.
Another problem, even earier than the Key Problem. When I drove it, the Electronic shifter did not want to gear down. It only worked when I stopped and turned the key on and off, making it very cumbersome to gear down for added tourque in turns and mud. I may have to replace the gear sensor in the engine area and wondering if anyone had similiar trouble in the past.
Please advise and email to pameolikj@gov.nu.ca
Thanks for your help ahead of time.
Eskimo
Old 07-04-2003, 03:56 PM
Woody_YZF's Avatar
Last Online: 01-11-2015 12:36 PM
Default Re: '99 Foreman TRX450ES (Electric Shift) Problem
I didn't think Honda's had problems. I wish I could tell you the problem. I'm sure someone here can help out. By the way welcome to ATM, we hope to see you post often.
Old 07-04-2003, 04:01 PM
Madman393's Avatar
ATM Founder
Last Online: 02-27-2011 05:04 PM
Like Woody said, welcome to the site! As far as your problems are concerned, you might want to hit the new key switch with a multimeter. New does not necessarily mean good. I suspect that you may have a bum switch that is not providing continuity when enabled. As far as the gear shifter, I will have to defer to some others out there for assistance.
Old 07-05-2003, 12:02 PM
quadrider32's Avatar
Last Online: 02-04-2012 05:56 PM
Get another key switch and if it doesnt work return it. But if that doesnt work I have no clue what the problem is??
Old 07-08-2003, 01:15 PM
I did try a different new key switch. I think somehow the salt buggered something in the electrical system and the ATV is due for target practice for my new .223.
New parts take time, and the summer is really short, so I gotta get on the horn.
Thanks anyway guys, hopefully there will be others who have had similiar woes post their suggestions. In the meanwhile, I'll be tracking my parts in the mail.
Eskimo
Old 08-01-2003, 12:57 PM
I got the key switch thing corrected.
On the old key switch, which I cut out and exposed the wires bare, it required me to connect the pink, black and all red wires together to get it running normal. On the new key switch, in which I had two, the electrical continuity check only OK'd the red and black connection when I turned the key on, and leaving out the pink one. So in the new key switch, I connected the pink with the black without cutting them and put it in the ATV and voila.
I won't explain how it works, you tell me, I gotta go.
Eskimo
Old 08-01-2003, 08:45 PM
Woody_YZF's Avatar
Right on, good to hear you got it working.
Old 08-27-2003, 12:25 AM
Last Online: 05-06-2004 10:54 PM
flasher Re: '99 Foreman TRX450ES (Electric Shift) Problem
hello eskimo
glad to hear you got your key to work.as for the problem with you es i might be able to help a little as i had the same thing go wrong on mine. i changed the handel bar shiffter (at $100) just to find out that was not it. then the senser on the motor(at aroud $30) . not that ether. it was a broken wire on the right side rear wheel.where they plug in . so i cut out the plugs spliced them together. works good now. hope this helps
woody146.
Old 08-27-2003, 02:04 AM
Age is a state of Mind
Last Online: 05-21-2018 07:56 AM
Hey, welcome to ATM woody146, we are getting a lot of us on here... Hope to see you back often.
Old 08-27-2003, 09:28 AM
MotoMan's Avatar
First of all I would like to welcome Woody146 and ESKIMO to the site!!
It sounds like you may have a viable solution to your electric shifting woes ESKIMO. Let us know what you find.
Post often guys!!
Old 10-25-2007, 11:09 PM
Last Online: 10-25-2007 11:10 PM
these bikes are electric shift-so if battery voltage gets alittle weak they dont shift well-try
charging battery
clean out the shift buttons
check voltage at shift buttons-ur key promblem could causing a voltage problem(check at shift buttons)
good luck
Similar Threads for: '99 Foreman TRX450ES (Electric Shift) Problem
polaris electric 4x4 hub problem muddymo1 ATV/UTV Forums 1 09-02-2008 11:46 PM
down shift and up shift without clutch????? busaturbo15 General Discussion 11 09-12-2007 11:12 AM
Gear Shift Lever problem pdmoyes 2-Stroke Dirt Bikes - Honda 8 10-18-2005 06:35 PM
valve adj. for 04' 450 s foreman yooper450 ATV/UTV - Honda 6 04-26-2005 06:06 PM
TRX450 foreman Smashinz2002 ATV/UTV - Honda 2 06-14-2004 09:30 PM
