Go Back   All Things Moto! Dirtbike Forums > Dirt Bike - ATV - Suspension Forums > ATV/UTV Forums > ATV/UTV - Honda
Old 09-30-2003, 12:11 PM
broorda's Avatar
Last Online: 10-13-2005 08:17 AM
86 honda 250r quad? what fuel mixture?
I have on simple question, i just traded for an 86 250r quad, the guy i got it from told me he was mixing it 32:1 but i see on the plastic right next to the cap it says 20:1
what would everybody suggest that i mix the gas and oil at?
also i would appreciate any advice on these quads that i could get, i have had many mx bikes and still do but just dont know a whole lot about the 250r quad except its fast!!
Old 09-30-2003, 09:23 PM
02_400ex's Avatar
Last Online: 04-11-2012 07:17 PM
Default Re: 86 honda 250r quad? what fuel mixture?
use 32:1 it is the best mixture i think.it says 20:1 because oils wernt as good back in the day.
Old 09-30-2003, 09:53 PM
Woody_YZF's Avatar
Last Online: 01-11-2015 12:36 PM
If you are using synthetic oil, you can mix it as lean as 40:1, but I would suggest 32:1 or even 24:1 if you are using a petroleum based oil.
Old 09-30-2003, 10:11 PM
Age is a state of Mind
Last Online: 05-21-2018 07:56 AM
Holy cow... I can't believe 2fun hasn't responded... He has 2 of them and can give you all sort of info.
Oh, I just realized this is in the other ATV section. I'll move it to the Honda forum and you should get some more replies ASAP.
Old 10-01-2003, 02:37 PM
2fun's Avatar
Last Online: 02-06-2018 12:12 AM
Thumbs up Re: 86 honda 250r quad? what fuel mixture?
Ist off, congrats!
Depending on how it was taken care of prior to your aquisition of it, you may have a great quad indeed!
Many of them have really been abused though!
Some good suggestions have been made here.
Let me add my 2 cents since as Woody_CRF has stated I currently own two, and have owned a total of 4 different 250R's over the years.
Synthetic oils offer superior protection as opposed to the older conventional oils (petroleum).
The 20:1 that is on the tank reflects the types of oils available back in the early to mid 80's.
These oils were inferior to the oils available today.
32:1 is a common ratio that people use today with many petroleum based and even some synthetics.
Oil does more than just lubricate, it also helps the rings to seal for better power.
I have heard of people running a good quality oil at ratios clear down to 16:1 for added power, though I have a hard time believing that there is a huge difference, or even one that would be noticed without a dyno.
I used to use Golden spectro ( a semi-synthetic oil) at a ratio of 40:1 and had excellent results as far as protection goes.
I ran my 330 at this ratio for 2 years, and the cylinder still has the cross hatch marks on much of the cylinder.
I now use Amsoil 2000 fully synthetic at a ratio of 50:1 for 2 years now, and have had no problems with seizure, or premature wear.
A mechanic whom I respect who is also a member of this site (albeit he rarely seems to pop in anymore {HarldlyDangerous})
can attest to the Amsoil also.
I have heard of people running it as lean as 100:1 or more, but for me, I don't feel comfortable stretching it out that thin.
If you don't have any mods to increase the compression, or advance the timing, I would stick with super unleaded for fuel.
Hope this helps.
Old 10-01-2003, 04:18 PM
Desert Rat's Avatar
Last Online: 03-24-2008 12:26 PM
I've owned several two stoke quads including a 250r I've had for several years now. I've ran them all on 50/1 Golden Spectro for years (and two stroke motorcycles for years before the quads even came out) with 15/50 Mobil synthetic in the transmissions since it came out. Very satisfied with the performance, but I don't skimp on maintenance cycles either. The old 20/1 requirement was partly due to the older oil technology and partly do to hopes of engine longevity (very conservative) by the manufacturers.
Old 10-06-2003, 05:18 PM
broorda's Avatar
thanks
Old 10-06-2003, 08:11 PM
MotoMan's Avatar
Yep, 2fun is our resident 250R expert.
He is like the 250R god.
Old 10-07-2003, 04:28 PM
2fun's Avatar
thanks
No prob!
Like to help out a 250R brutha when I can.
Old 10-07-2003, 04:30 PM
2fun's Avatar
Wink Re: 86 honda 250r quad? what fuel mixture?
Well, I don't think I would go THAT far, but thanks for the compliment anyways!
I'm sure there is still way more that I DON'T know than what I do, but I do pick up little bits of info from time to time that help once in a while.
Old 10-07-2003, 06:49 PM
MotoMan's Avatar
And you do a damn fine job too 2fun.
There, that is the end of my complimenting, now I will resume the normal "pic on 2fun" mode.
Similar Threads for: 86 honda 250r quad? what fuel mixture?
88 RM250 Fuel Mixture Devin_01 2-Stroke Dirt Bikes - Suzuki 2 09-11-2008 10:09 PM
Check the oil/fuel mixture? D3luxe General Discussion 4 02-08-2008 07:12 AM
Yz 85 fuel mixture???? yz85zak 2-Stroke Dirt Bikes - Yamaha 3 05-23-2007 10:32 PM
fuel/air mixture thoryamaha22 2-Stroke Dirt Bikes - Yamaha 7 08-13-2004 08:56 PM
air fuel mixture? tailwhip ATV/UTV - Yamaha 7 12-23-2003 01:08 AM
