Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > ATV/UTV Forums > ATV/UTV - Polaris
trailblazer 250
This is a discussion on trailblazer 250 within the ATV/UTV - Polaris forum, part of the ATV/UTV Forums category; here's the thing i just got a trailblazer 250 engine with the cdi and stuff to make it run, this ...
Old 05-05-2007, 10:19 PM
Last Online: 05-08-2007 08:57 PM
Default trailblazer 250
here's the thing i just got a trailblazer 250 engine with the cdi and stuff to make it run, this motor is for a project i am working on and need to make sure it runs before i invest my time and money into it. all i need to do is get it all hooked up and make sure it sparks. i plugged in the cdi and the coil turned it over and no spark. i don't have the rest of the wiring so i am at a loss of what the three other wires are and where they go. there is a solid yellow, yellow with a red stripe, solid brown,coming out of the motor. there is a solid black that i believe is the kill wire coming out of the cdi. any help would be great. i would go buy a book to figure this out but im not sure i want to spend money on this motor. it does have over 100lbs of compression so the motor is good but i just need to make sure the electrics are good before i go any further thanks,
Nathan
Old 05-05-2007, 10:32 PM
***RETIRED FOR GOOD!!!!***
Last Online: 07-23-2009 01:36 AM
Default Re: trailblazer 250
Go to any dealer and ask if they can print you off a wiring diagram. Do you have the key switch and all that? If not, maybe that is the one thing you need. If you don't have a switch on, or killswitch hooked, it will be like trying to fire it up with the plug wire off. Get a diagram though and check them out. Should tell you what they are for. But the wires DO sound like they go to a key switch or similar part.
Welcome to
Old 05-06-2007, 09:08 AM
ok, never thought of that i will do that tomorow. thanks,
Nathan
Old 05-08-2007, 08:57 PM
ok can someone tell me how this ignition system works....i don't understand how the coil gets a signal to fire.....i know that most if not all ignitions need some kind of signal to fire this one seems to not have one...am i missing something? i took of the flywheel to test the coils figuring that i might find a pulser coil and or a points system... but no such luck could someone please explain what i am missing thanks,
Nathan
Old 09-07-2007, 02:42 PM
gen3usa's Avatar
Last Online: 06-28-2009 11:18 PM
first thing we need to know is what year are we talking about? most have an alternator with CDI, the coil and magneto will create the pulse threw the CDI. but knowing what year will help alot.
Old 08-25-2009, 05:49 PM
Nolengerke's Avatar
Last Online: 08-25-2009 08:39 PM
Goto bikebandit.com and look at the entire ign system components. I didnt get spark on my trailblazer till i got a new ignition. The red wire at the iginiton is constant and the red/white(I beleive) was the IGN power.
Similar Threads for: trailblazer 250
01 Trailblazer 250 hard starting tinker1980 ATV/UTV - Polaris 4 08-25-2009 05:46 PM
03 Trailblazer 250 not starting txtrp70 ATV/UTV - Polaris 2 02-07-2009 02:39 AM
Need help with a 250 trailblazer / odd problem ktrim ATV/UTV - Polaris 4 09-07-2007 02:35 PM
2000 Polaris Trailblazer Wont Start Trabmai796 ATV/UTV - Polaris 3 11-18-2006 11:02 PM
98 trailblazer 250 wont start. nate650 ATV/UTV - Polaris 8 11-20-2004 04:17 PM
