Go Back   All Things Moto! Dirtbike Forums > Dirt Bike - ATV - Suspension Forums > ATV/UTV Forums > ATV/UTV - Polaris
Old 07-29-2005, 12:15 AM
Faded's Avatar
Last Online: 04-23-2018 07:16 AM
Default Polaris Oil Injection Adjustment
Does anyone know the adjustment procedure for the oil injection pump on a Polaris Xplorer 300 4x4? I had to replace the throttle cable on a friend's machine and I need to get the OI cable properly adjusted. Any help would be appreciated.
Old 07-29-2005, 12:39 AM
SirFallsALot243's Avatar
Default Re: Polaris Oil Injection Adjustment
Why wouldnt you disconnect it and run premix?
Old 07-29-2005, 01:21 AM
Faded's Avatar
Because it's not mine...
Old 07-29-2005, 01:36 AM
Woody_YZF's Avatar
Last Online: 01-11-2015 12:36 PM
I just thought they ran automatically. I have no idea.
Old 07-29-2005, 02:32 AM
Faded's Avatar
No, the throttle cable is "y"ed, one runs the carb and the other controls the oil injection. Both have threaded adjusters...I just need to know what to adjust it to!
Old 09-07-2007, 01:01 PM
gen3usa's Avatar
Last Online: 06-28-2009 10:18 PM
take the cover off the oil injection and the upper throttle box on the handlebars, have someone push the throttle, watch the oil inj. cable cam, they should both move upon cable movement, if the oil injection cable has slack it will not move perfectly with the throttle, adjust the oil inj. to meet with the throttle cable, check the cam return spring at this time, i had mine break with the cam in the wide open position, had it been the other way i would have lost my motor. if the spring shows signs of rust you should replace it!
Similar Threads for: Polaris Oil Injection Adjustment
Honda Cr 250 '02 empty injection.. hgt 2-Stroke Dirt Bikes - Honda 1 07-01-2005 07:50 PM
fuel injection??? dixienw123 General Discussion 2 01-09-2005 05:29 PM
Electronic Injection Crazy General Discussion 16 10-17-2004 09:44 PM
What exactly does Fuel-injection do? ThumperCRF250 General Discussion 2 05-01-2004 05:47 PM
polaris trail blazer 250 oil injection. nate650 ATV/UTV - Polaris 9 04-19-2004 11:28 PM
