02 scrambler 500 pops out of gearThis is a discussion on 02 scrambler 500 pops out of gear within the ATV/UTV - Polaris forum, part of the ATV/UTV Forums category; Hopefully someone knowes what to do. it pops out of gear when you get on it. i tried unhooking the ... |
| Hopefully someone knowes what to do. it pops out of gear when you get on it. i tried unhooking the linkage and putting it in gear but it still pops out can someone help. |
| had a 400 sport doing same thing snap ring on main saft in trans came off leting sift dog not engage all the way noy bad fix 1needle bearing 1snap ring this was on a 98 model |
| thanks that will help |
| when my 2001 scrambler did that it was just a linkage adjustment under the shift lever (automatic ) |
| also inspect the shaft that goes into the trans at the top, if the orings and shaft wobble you may have an issue there. do you have oil that weeps from the top? my brothers did the same thing, and between the shift linkage and the orings it was enough to cause the shifting to not engage. also inspect the shift handle where it goes threw the plastic fender, if it rubs it may be causing the bar to vibrate the shifter to disengage. |
| yz80 pops and backfires before powerband HELP | haney121 | 2-Stroke Motorcycles - Yamaha | 0 | 11-26-2007 03:02 PM |
| most bad *** scrambler ever? | crdude | Photo & Video | 4 | 10-16-2007 01:27 AM |
| Pops wants to get a quad, what do u think? | weekend warrior | ATV/UTV - Yamaha | 15 | 11-23-2006 01:10 AM |
| pops out of gear.... | MONSTER450 | 4-Stroke Motorcycles - Kawasaki | 52 | 02-26-2006 05:57 PM |
| Scrambler 500 | quadrider32 | ATV/UTV - Polaris | 17 | 09-23-2003 12:39 AM |
