Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > ATV/UTV Forums > ATV/UTV - General Discussion
pull behind mowers
This is a discussion on pull behind mowers within the ATV/UTV - General Discussion forum, part of the ATV/UTV Forums category; tryin to buy 14.1 acres to put a house and a small track on and i need a mower . ...
Old 04-27-2005, 09:53 AM
Twiztid One's Avatar
Psycophic Dirt Rydas
Last Online: 09-20-2005 11:04 AM
Question pull behind mowers
tryin to buy 14.1 acres to put a house and a small track on and i need a mower . was wondering if any of you all have or have used one of these pull behind mowers that you can attach to the back of a ATV . a company called Swisher makes several models with different brands of engines on them , let me hear your guys opinions ?
Old 04-27-2005, 11:54 AM
psycho393's Avatar
I got DUALS
Default Re: pull behind mowers
Get us a linky so we can see them. I've seen them but never personally used one.
Old 04-27-2005, 12:31 PM
crdude's Avatar
BRAAAAAAAAP
Last Online: 10-27-2009 05:29 PM
my uncal had one that attatched to the front of his utility quad, we soon found out that when he would turn, that the front tires ripped up that yard
Old 04-27-2005, 01:42 PM
here's a link [Only registered and activated users can see links. ]
Old 04-27-2005, 01:58 PM
Desert Rat's Avatar
Last Online: 03-24-2008 01:26 PM
If you don't have limited slip on the rear and the front in 4x4 mode the quad will tear up lawn. Wouldn't matter that much in a field of weeds. Swisher also sales plows, loader buckets, etc. that mount on a front univeral plate that can be used for lighter duty stuff.
Old 04-27-2005, 04:14 PM
quadfather03's Avatar
Last Online: 07-26-2009 01:06 AM
they are alright ive seen some used but the quads always had turf tamers on the rear and smoother nobbies on the front. If you go slow they cut fairly nice not a professional mower cut but close. Good luck.
Old 04-27-2005, 09:35 PM
Woody_YZF's Avatar
ATM Store Mgr & ATV Mod
Last Online: Today 03:27 PM
Those are interesting. Do they make a quad that has a differential in the rear? I would think the quad would rip the lawn up.
Old 04-27-2005, 09:44 PM
SirFallsALot243's Avatar
AKA Ineedabettrbike
Last Online: 07-22-2008 02:44 AM
For up to $3200, spend a little more and get a Kubota with a front end loader so you can use it for track maintence as well.
Old 04-27-2005, 09:59 PM
psycho393's Avatar
I got DUALS
Most of your utility ATVs will not tear up a lawn. They will leave tracks but that'd be about it. I'd recommend going with a newer Yamaha, Kawasaki, or Suzuki since they have independant rear suspension (read differentials) and differential locks for the front end.
Old 04-28-2005, 08:30 AM
mtk's Avatar
mtk mtk is offline
Mr. Titanium Implant
Any quad with a solid rear axle will most definitely tear up the grass every time you turn it. It can't help but do it. Not to mention that tires that make a utility quad useful are most definitely not turn-friendly. I wouldn't run the ITP Mud Lites on my Big Bear on any grass I wanted to keep nice. But they work wonderfully in "work" applications.
Old 05-02-2005, 02:54 AM
hardlydangerous's Avatar
Last Online: 01-09-2009 03:16 AM
You need yourself a YAMHA terra-pro
Hard to find though. As far as i know they were one of the only 2wd atv with a locking rear diff and a live PTO. Perfect for lawn cutting.
When I worked for yamaha we had one that we used to cut the dealership yards with.
If you use a utility quad I found it's best to attach them to the front. heavy utility quads tend to mash down the grass then after a few days you have high spots where the tire makrs were. having the mower infrom will eliminate this problem.
The mower I run for a freinds lawn care service is a home mad job using an sears riding mower deck and a 6hp Honda engine. It hooks up to the front of his ATV (Honda fourman 500)and uses the winch to raise and lower the mower.
Old 05-04-2005, 04:47 PM
thanks for all the replys guys and i have just decided to buy a comercial ridin mower . want somethin that i can mow fast with to save time , looks like i'll haft to spend about $6,000 unless i can find one used .
Old 05-12-2005, 01:58 PM
I've run a 48" zero turn Simplicity citation (by Farris) for a couple seasons now.
Bullet proof designs and well worth every penny. $7000 CND
It was treated to Amsoil lubricants at new and has never had a single problem unlike out JDeere's that are always breaking down.
plus it's FAST. (aprox 10mph)
IMO if you want somthing built to last go with a dual hydro ststem and it must have a filter system and reservoir for the hydraulic fluids.. the down fall to most lawn equipment is HEAT and DIRT. A filters hydro sytem with quality fluids will eliminate any problems. Zero turn is the way to go IMO
Old 06-28-2005, 04:17 PM
Last Online: 08-15-2008 12:01 PM
Go to [Only registered and activated users can see links. ] and take a look at a belly mount mower for ATV's (made by Swisher)
Old 07-13-2005, 09:25 PM
dispatchrider's Avatar
Last Online: 10-09-2006 04:19 PM
absolutely awesome I think my husband would really enjoy mowing the lawn more if it attached to quad.
Old 07-13-2005, 09:52 PM
chris99's Avatar
LFTSTMT 660 RIDER
Last Online: 08-10-2007 01:18 PM
oh yea i would mow every day! buy me one!
Old 07-14-2005, 02:10 AM
SandDiegoDuner's Avatar
Last Online: 06-14-2007 11:38 PM
I just got a new Cabelas catalog that had all sorts of pull behind and front mounted mowers for ATV's. You might want to check them out if you live close to one.
Old 08-23-2005, 08:11 AM
this what i finally got and it works very well for what it does . we bought the mower , bucket and a tiller for it but i'm very happy with it so far . we have 7 jumps up so far on 1.1 mile mx track and more to come .
Similar Threads for: pull behind mowers
EZ pull clutch Hooptie31 2-Stroke Motorcycles - General Discussion 23 03-21-2008 05:32 PM
Clutch pull hard... huffdaddy70 4-Stroke Motorcycles - Yamaha 22 05-30-2004 08:35 PM
Easier clutch pull Peetey 4-Stroke Motorcycles - General Discussion 3 12-28-2003 02:39 PM
E-Z Pull Clutch BlueBlur426 4-Stroke Motorcycles - Yamaha 1 12-19-2003 03:12 PM
