2001 Raptor 660R Question!!!!This is a discussion on 2001 Raptor 660R Question!!!! within the ATV/UTV - General Discussion forum, part of the ATV/UTV Forums category; Sweet!! So when's the dunes trip??... |
#121
| Sweet!! So when's the dunes trip?? |
#122
| Going to st.george next week. Question..... My bike's plug looks good. It dies if the RPM's are up high and i put in the clutch it just stops. Starts/Idles fine, it does run VERY well though doesn't have a problem off the line or high or mid throttle only complaint it dies when I'm high in the RPM range and let the clutch in. Is it my Air Mixture? Ronnie |
#123
Yet, you can shift in lower RPM's (pull in the clutch) without a problem? That's weird. |
#124
| Well..... Yes at low RPMS it is okay but at high redline and pull the clutch in it dies i can start it easy though. Would that be air mixture or it running lean. |
#125
| btw Shifting has nothing to do with it. Just pulling in the clutch is when it dies i can lug it around fine. |
#126
| But it runs fine until you pull the clutch in? You've got me on this one? |
#127
| it might have a slite problem with how it idles. I wonder if a clogged air filter would do it? It didn't have this problem until this work was done to it. I think i need to reset the settings like the dynojet instructions say .... |
#128
| Is it only at high rpm? |
#129
| Does it pop or anything? Can you run it up to high RPM's, then let itself idle back down and no issues? |
#130
| It runs perfect minus the fact that the damn thing when I pull the clutch in just dies. Lets say from 2,000 - Redline. I noticed the K&N PowerLid was very dirty so I got my recharger kit out and am currently cleaning it. The very tip of my plug looks a little WHITE I remember before it was darker. I wonder if i just need to go up to the next size jets in eatch carb the jets and everything are how it was before I did all of this stuff. You would think that doing all of this stuff would require more fuel ..... Am I correct? |
#131
No popping or Studdering or anything. I can run it to redline go first through 5th gear and lets say i'm going 10mph and pull the clutch in in 3rd gear 50% of the time it will die. I know that they didn't change any jets all they did was screw with the screw on the outside of the carb. |
#132
| Depending on the port work, you could and usually do go smaller on the jetting. My CRF was at a 178 main, and now I use a 170. |
#133
#134
FYI .. we'll be out at Little Sahara this weekend. If your going down let me know. |
#135
| I don't know RSheppick. Kind of sounds electrical?? Crunk, I'll have to see if we can come down for the day on Saturday or something this weekend? Where are you going to be camping? |
#136
| They didn't even change the spark plug so I don't know if it is even jetted correctly. Im going to go home after work and make sure the carbs are set correctly. You don't think I need higher octane gas do you? |
#137
#138
#139
#140
| 12:5:1 102MM South Valley thinks is the air fuel mixture screw he thinks he set it to rich he said it was to lean when he first had it apart I know dyno jet recomends 3 turns out from closed. |
| Raptor 660r Diaphrams | stormbringer | ATV/UTV - Yamaha | 4 | 04-27-2007 02:00 AM |
| 2001 Raptor Trans Question | rsheppick | ATV/UTV - Yamaha | 6 | 11-01-2004 10:04 PM |
| Bombardier DS 650 V.S. 660R Raptor | Ridin old bikes | ATV/UTV - Yamaha | 10 | 08-22-2003 10:21 PM |
| WTB RAPTOR 660R | Punting_Midgets | Motorcycles & ATV's | 4 | 03-22-2003 01:09 AM |
| WTB RAPTOR 660R | Punting_Midgets | Wanted Items | 1 | 03-18-2003 09:45 PM |
