Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 4-Stroke Motorcycle Forums > 4-Stroke Motorcycles - General Discussion
valve adjustment
This is a discussion on valve adjustment within the 4-Stroke Motorcycles - General Discussion forum, part of the 4-Stroke Motorcycle Forums category; i was just wondering if anyone knos how to adjust the valves on a 95 xr 250r......if so can u ...
Old 02-11-2004, 01:39 PM
Last Online: 01-02-2005 03:41 AM
Default valve adjustment
i was just wondering if anyone knos how to adjust the valves on a 95 xr 250r......if so can u plz tell me....thx
Old 02-12-2004, 12:52 AM
Default Re: valve adjustment
Does anyone no...?
Old 02-12-2004, 01:03 AM
Mitch_CRF_250's Avatar
Mitchell Thelen
Last Online: 02-12-2006 09:59 PM
Sorry never done it. I was looking for some tips myself.
Old 02-12-2004, 01:30 AM
MATTXR250R's Avatar
Retired ATMer
Last Online: 08-27-2008 08:35 PM
Yes I can walk you through the whole procedure. I have adjusted the valves on my 91 XR250R tons of time and the 91 is the same as yours.
First off here is the valve clearance specs:
INTAKE: .001"-.003"
EXHAUST: .002"-.004"
Ok first off...Get your seat and fuel tank off. Look on the valve cover and you will see 4 caps. Take all 4 caps off. Incase you don't know the 2 valves at the back of the engine are the Intakes and the front valves are the exhaust valves. now....Look down on your stator cover and you will see 2 more covers. Take both of them off...turn the engine over COUNTER CLOCKWISE using the nut on the crank on the bottom hole.
Now watch the intake rocker arms...turn the engine over until you see the intake rockers go DOWN..now..when they COME UP look through the top hole and watch and you will see a sideways "T" with a vertical line to the left of it...line that line on the stator rotor with the notch in the crankcase...now..pull up and down on all 4 rocker arms and make sure you feel some PLAY..if you do you are at TDC(Top Dead Center)on the compression stroke.
Now its time to get down to business...I always do both Intakes first and then the exhaust...so get your .001" and .003" feeler gauges. You are wanting to slide them between the Tappet(adjusting screw)and the subrocker arm. Get your .001" and slide it in..if it goes IN then you know right there that the valve is NOT to tight....now try and slide in the .003" gauge...if it goes IN then you are too LOOSE. With the Intakes you are wanting to get the .001" gauge IN but not the .003".
Its the same for the exhaust except you want to get the .002" IN and not the .004".
Now if you have to adjust....lets say for example the .002" won't go in on 1 of the exhaust valves...that valve is TO TIGHT and you will need to adjust...take a 10mm wrench and loosen the locknut...back the tappet screw out COUNTER CLOCK WISE about 1/8 of a turn and hold it there with a screw driver and just barely tighten the locknut down..try the gauge again and get it to where the .002 will go in and not the .004. Once you have that correct...hold the tappet with a screwdriver to keep it from turning and tighten the locknut all the way down...after tigtening the locknut go back and re-check all the clearances. If you need anymore help..just ask.
Old 02-13-2004, 02:25 AM
Aus_Rider_22's Avatar
Mod From Down Under
Last Online: Yesterday 07:39 AM
Good walkthrough Matt!!!!!
Geoff.
Old 02-13-2004, 06:11 AM
Yardpro393's Avatar
393 race team
good info matt
Old 02-15-2004, 09:20 AM
Dirtbikindad393's Avatar
Your ATM Amsoil Dealer
Last Online: 10-14-2009 10:24 PM
Nice write up Matt.
Old 02-15-2004, 09:26 AM
huffdaddy70's Avatar
Last Online: 07-10-2008 07:49 PM
Nice job matt! That should be very helpful!
Old 02-15-2004, 01:26 PM
LoKi's Avatar
Long Live the Goat
Last Online: 01-12-2009 06:29 PM
Indeed, and the one on your site with pics is great as well.
Old 02-15-2004, 02:36 PM
MATTXR250R's Avatar
Retired ATMer
Thanks Guys...just glad to help out
For those of you that haven't see the one on my site here ya go
Old 02-15-2004, 05:17 PM
Yardpro393's Avatar
393 race team
you are turning out to be quite the helpful guy matt
Old 02-15-2004, 06:18 PM
MATTXR250R's Avatar
Retired ATMer
I try to be Steve
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads for: valve adjustment
Valve adjustment on the YFZ 450?? 2fun ATV/UTV - Yamaha 19 02-13-2009 09:31 AM
Valve Adjustment! YFZKID ATV/UTV - Yamaha 5 04-19-2008 11:17 AM
525 exc valve adjustment sledhedz900iq 4-Stroke Motorcycles - KTM 13 05-06-2006 11:40 PM
Valve adjustment & other ?'s TRXman86 ATV/UTV - Honda 13 10-17-2004 11:42 PM
valve adjustment? Riley_400 4-Stroke Motorcycles - KTM 11 03-23-2004 09:23 AM
vB.Sponsors
