All Things Moto! Web Forums
Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 4-Stroke Motorcycle Forums > 4-Stroke Motorcycles - General Discussion
Valve adjustmants made, now no compression!
This is a discussion on Valve adjustmants made, now no compression! within the 4-Stroke Motorcycles - General Discussion forum, part of the 4-Stroke Motorcycle Forums category; Hi, just got my new shims in today, clearence now seems all good. Put it all back together and it ...
Old 02-09-2008, 05:48 PM
Last Online: 04-08-2009 11:50 AM
Default Valve adjustmants made, now no compression!
Hi, just got my new shims in today, clearence now seems all good. Put it all back together and it has no compression!
This is on a yz 250f 01
I have done everything the manual said.
I had a radiator off and oil drained.
The cams all lined up and 12 pins inbetween etc..
I dont get it! Have i missed something!!!! I was getting dark!
Old 02-09-2008, 08:51 PM
Default Re: Valve adjustmants made, now no compression!
Are you sure the cams are timed to the crank correctly?
Old 02-10-2008, 09:57 AM
Well it look to be as it should, all lined up with the timing mark!
its wiered! If a valve is slightly out will it amke a difference?
Maybe i took wrong readings?
Old 02-10-2008, 11:52 AM
I would double and triple check the valve clearances and the timing. Rotate the motor through a few times and check it again. Also make sure your decomp cable isn't hanging up (if you still have the manual decomp lever). And, make sure you have the spark plug in
Old 02-10-2008, 07:07 PM
It was the exhaust valves! Far too tight! I did the wrong settings... intact on exhaust! Anyhow sorted it and started up 1st kick! Ran perfect for 30mins then my bottom end went!!!! So crank or big ends starting to seize!
Problems after problems!
Old 02-11-2008, 02:58 AM
crdude's Avatar
BRAAAAAAAAP
Last Online: 10-27-2009 05:29 PM
sorry to hear about your bad luck, have fun gettin that 4 stroke runnin again.
Similar Threads for: Valve adjustmants made, now no compression!
I wonder if he made it? Freak General Discussion 6 04-26-2009 08:44 PM
Old vid I made Freak Photo & Video 5 12-21-2007 12:30 PM
exhaust valve/power valve function / problem mjcho 2-Stroke Motorcycles - General Discussion 3 09-11-2007 08:33 PM
I have made a sig. now how do i put it on? schwen_108 Photo & Video 3 08-26-2004 05:47 PM
made a new sig Z-Man 393 General Discussion 7 05-01-2004 11:22 PM
