Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 4-Stroke Motorcycle Forums > 4-Stroke Motorcycles - General Discussion
tdc? help
This is a discussion on tdc? help within the 4-Stroke Motorcycles - General Discussion forum, part of the 4-Stroke Motorcycle Forums category; I was just wondering how to find top dead center on my 2005 crf450r?...
Old 10-19-2009, 06:56 PM
Last Online: 10-22-2009 08:29 PM
Default tdc? help
Old 10-19-2009, 08:11 PM
kwmotocrosspunk's Avatar
Im SOUNDERS Till I Die!
Last Online: Yesterday 05:44 PM
1. pull out your manual (always!)
2. pull off the left side cover to expose the side of the crank shaft, (the side with your charging system, usually the left side)and you will see a big nut, find wrench to fit nut
3.remove your spark plug
4. there will be another circular metal cover with a few holes in it, it is also most likely magnetic, on the top rim of this cover there will be markings with lines imprinted onto it. mounted on the engine case will be a little metal arrow, when these lines match to the arrow, they will tell you where in the stroke your bike is, compare that with your manual on which mark is TDC and line them up(one might actually say TDC)
if you are trying to get the bike on TDC of the compression stroke, as you turn the bike over with the wrench, put your finger over the spark plug hole and feel which stroke has the most pressure building up, once you find that stroke, line up the markings as they should be very close already
or remove the valve cover, when the piston is TDC of the compression stroke, the rocker arms will be loose and able to rattle, aslong as all the rocker arms rattle then you are on your compression stroke, then line up the TDC marking
...is that better Jedi
Old 10-19-2009, 08:29 PM
crfjedi393's Avatar
Obi Wan Kenobody
Last Online: Yesterday 01:16 AM
Dang, Nick. Can your repeat that in English?
Old 10-19-2009, 11:11 PM
cad a dhéanann tú gceist?
