Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 4-Stroke Motorcycle Forums > 4-Stroke Motorcycles - General Discussion
Shim measuring
This is a discussion on Shim measuring within the 4-Stroke Motorcycles - General Discussion forum, part of the 4-Stroke Motorcycle Forums category; I have a question about measuring the shims on a bike when it's time to change them. When using the ...
Old 07-12-2005, 08:08 PM
madcow393's Avatar
Custom User Title:
Last Online: 03-23-2009 09:57 PM
Default Shim measuring
I have a question about measuring the shims on a bike when it's time to change them. When using the micrometer (that is the right name for the tool isn't it?) how tight should it be on the shim. When I checked them a while back a couldn't really figure out if I was tight or loose.
Old 07-12-2005, 08:45 PM
Last Online: 01-24-2009 08:41 PM
Default Re: Shim measuring
Here's a web page on the subject:
The second item answers your question...
Old 07-12-2005, 09:08 PM
madcow393's Avatar
Custom User Title:
Hey thanks, I never knew that's what the ratches was for!
Old 07-12-2005, 09:22 PM
I've been RM-Zedded
I don't have a cool micrometer, but I have tons of other shims (bought the kit) so I measure it, and then start measuring some others that are close, and I soon find out what it is.
Old 07-12-2005, 10:05 PM
zuki's Avatar
Last Online: 03-05-2010 01:02 PM
I havent had to shim mine yet....but Ive heard that the shim thickness is printed on there? BTW, with micrometer I have, there is a knob on the bottom, and you twist it untill it clicks(hard to explain). Think of it as a gas cap. Once it clicks, you know your done
Old 07-12-2005, 10:19 PM
Keetoman393's Avatar
Out of control!
Last Online: 02-16-2010 04:43 PM
That knob is what he is talking about as being the "ratchet". If you tighten it too tight, the calibration may/will be screwed up.
Old 07-12-2005, 11:30 PM
I've been RM-Zedded
LOL, I can tell you haven't shimmed yet (as you said), because the numbers are often times worn off.
Old 07-12-2005, 11:38 PM
RMZracer212's Avatar
Thumpin it up!!!
Last Online: 09-28-2009 10:01 PM
plus the size on them may not be right anyway. They could eather be worn down or not even made the right size. I have the kit and I could have 3 diff shims all marked the same size be 3 thousnths off from each other.
Old 07-13-2005, 08:25 PM
madcow393's Avatar
Custom User Title:
The measuring I was talking about is because after a while the shim gets compressed and you have to know how much it was compresed in order to select a new shim.
And hey Clay, when did you get a new bike?
Similar Threads for: Shim measuring
question about using measuring shims tonymtona 4-Stroke Motorcycles - Yamaha 4 04-18-2009 07:07 PM
fork oil measuring? pjg351 Motorcycle Suspension Tuning 8 11-07-2008 04:50 PM
fork oil measuring? pjg351 Motorcycle Suspension Tuning 12 03-23-2008 06:55 PM
Valve shim help madcow393 General Discussion 3 04-12-2005 10:19 AM
Measuring For chain alignment Dirtbikindad393 General Discussion 12 11-05-2003 09:25 PM
