Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 4-Stroke Motorcycle Forums > 4-Stroke Motorcycles - General Discussion
Help please!
This is a discussion on Help please! within the 4-Stroke Motorcycles - General Discussion forum, part of the 4-Stroke Motorcycle Forums category; ok i just got done rebuilding my 03 crf 450. i ended up putting a 12:1 piston instead of the ...
Old 06-30-2009, 09:14 PM
Last Online: 07-02-2009 09:09 AM
Unhappy Help please!
ok i just got done rebuilding my 03 crf 450. i ended up putting a 12:1 piston instead of the 11.5:1 which was in it before. when i put it back together im almost possitive i got the timing marks dead on. ok so what its doing is when i get up to about half throttle it acts like its rev limiting and wont put out no more power. its really hard to get it to kick start but fires right up when i roll it off. so i feel like it could be like one tooth off on timing but i dunno. so anyone run into this or got ideas?
Old 07-01-2009, 07:41 AM
Mainjet2001's Avatar
Last Online: Yesterday 10:14 PM
Originally Posted by crfcollins112 View Post
its really hard to get it to kick start but fires right up when i roll it off. so so anyone run into this or got ideas?
Are you are sure your valves are adjusted correctly?
Also you should re-check the timing anyway.
Old 07-01-2009, 12:04 PM
I've been RM-Zedded
Yeah, I would recheck the timing and valves adjustment. It's not hard, and it would be worth the piece of mind.
Old 07-01-2009, 06:29 PM
yamahammer01's Avatar
Last Online: 08-05-2009 05:56 AM
i just rebuilt the whole motor in my 450, its an 02. used the same piston in mine. i had some problems like you are explaining and my timing was off, if the cam chain is streched a little, it will be hard to get it lined up right. what i did was get it where i thought it was and then i pushed the cam tensioner in with my finger and if the marks lined up then i was good to go. but i ended up timing mine bout 3 times before i got it right. also deffinately check the valves, but i would say it is for sure the timing. hope this helps.
Old 07-01-2009, 06:56 PM
2001hondacr125's Avatar
Last Online: Yesterday 05:07 PM
im going to throw this out, but wouldn't a bike do this when you dont take the slack out of the cam chain properly when its at TDC hits trowing the timing off and making the chain extremely tight? Im talkin about if you didnt even take the tensioner out or just put it back on without backing the tension off?
Old 07-02-2009, 07:06 AM
You need Honda's chain tensioner tool when removing and replacing the cam.
The one for the CRF250 is P/N 07AMG-001A100.
Not sure but I think it's the same for the 450 and it's in your service manual.
Old 07-02-2009, 10:06 AM
you can use a small flat head screw driver also.
Old 07-02-2009, 02:51 PM
I've been RM-Zedded
Yep, Iv'e used one more than once.
Old 07-06-2009, 07:47 PM
i just looked that tool up...and 83 bucks?! wow what a rip off and a half...i'll stick with a screw driver lol
Old 07-06-2009, 10:38 PM
Do you understand the tool?
Go back and read your #5 post.
If you don't take the tension off the chain, the cam gear will not come out nor will you get the chain off. That is what the tool does bud and holds the tension off the chain.
What does that $85 dollar tool do for you....can you guess now?
Mine was cheaper.
Old 07-06-2009, 11:16 PM
Freak's Avatar
Hook 'Em
Last Online: Today 12:23 AM
Mine was cheaper.
what a bully
Old 07-07-2009, 09:01 AM
I'm fully aware of what the tool does I'm not 3 lol. But what I'm trying to say is why should I waste that money when i can just take a flat head screw driver take the tension off then take the tensioner itself off? Then to put the tensioner back in, take the tension off the tensioner again and put the tensioner in holding the tension backed off tighten it down get the timing lined up on all 3 marks and holding the cam sprocket on the marks release the screw driver? I'm just pointing out how I do it, theres no need to try and fuss at me because I dont want to spend 83 dollars on a tool that a 2 dollar screw driver can do if used right. You know what I'm saying? Just throwing my 2cent out there.
Tags
crf450
