Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 4-Stroke Motorcycle Forums > 4-Stroke Motorcycles - General Discussion
Fouled Plug
This is a discussion on Fouled Plug within the 4-Stroke Motorcycles - General Discussion forum, part of the 4-Stroke Motorcycle Forums category; Just got my first 4 stroke, '91 Suzuki LT-F250 Runs good, but the plug is fouling out after a few ...
Old 07-28-2003, 11:06 AM
sfourtyfive's Avatar
Last Online: 08-08-2003 08:57 AM
Default Fouled Plug
Runs good, but the plug is fouling out after a few trips around the yard. It's black and wet. Bike doesn't smoke at all.
I've only had it a day, so I haven't had a chance to tear into it yet, just wanted to ask for some guidence before starting. Any clues on what to look at first?
Thanks,
sff.
Old 07-28-2003, 11:11 AM
Dell30rb's Avatar
Default Re: Fouled Plug
Plugs will foul. Pop a new one in there and ride.
If it fouls in a short time also, then you may have a problem.
Old 07-28-2003, 11:14 AM
The guy I got it from said this was a problem, and he'd just put in a new plug, 'bout 20 mins of riding around my yard and the plug was fouled. So I guess I've got a problem. ;o)
sff.
Old 07-28-2003, 12:20 PM
egoallenpoe393's Avatar
never a back turner
Last Online: 09-23-2009 03:13 PM
If its black and wet it is getting way to much gas.
A few things come to mind
First is the float bowl adjustmetn. If this is not correct it could be simply just poutring gas into the intack. You will need to take the carb off and set the float hight correctly
Second If the jetting is stock, (If You Know) the I would lean more toward the float, if it has been dinked with, then I would set everything to stock and see if that helps
But I have a feeling the float is not adjusted correctly
Old 07-28-2003, 01:02 PM
MotoMan's Avatar
Floppy
I will side with Ego on this one, sounds like the float level is off to me as well.
Check it out and let us know what you find.
Did you get a service/owners manual with the bike?
Old 07-28-2003, 01:52 PM
"Did you get a service/owners manual with the bike?"
Owner's Manual, yes. But it doesn't give details on the float height, or anything re carb maintence/repair.
I'll tear the carb down tonight, give it a good cleaning and take a look. Meanwhile I haven't had much luck looking on-line for manuals or tech info. A little different than I'm used to with the banshee, you can find diagrams for every nut&bolt online, along with detailed instruction to do just about anything. ;o)
Thanks for the help guys, I'll let you know what I come up with.
sff.
Old 07-28-2003, 02:02 PM
MotoMan's Avatar
Floppy
You may be able to call a Suzuki dealer and get the float height info you need. Most service departments should be willing to do that for you I would think.
While you are on the phone it wouldn't hurt to order that manual either if you plan on keeping the bike.
Old 07-28-2003, 02:03 PM
MotoMan's Avatar
Floppy
Oh BTW, welcome to ATM sfourtyfive!!
Old 07-28-2003, 02:16 PM
Lowco's Avatar
Last Online: 07-28-2007 06:43 PM
Could the choke be in the "ON" position or possibly stuck in the on position? Check the linkage/lever assy. Just a thought!
Old 07-28-2003, 06:44 PM
Yardpro393's Avatar
393 race team
a good starting point for most all carbs is to have the float seam parallel with the carb body. this should seat the float needle and the spring loaded pin in the middle should start pressing in.
Old 07-28-2003, 07:22 PM
MotoMan's Avatar
Floppy
Good advise yardpro, I was wondering if there was a "General" rule he could follow.
Be sure to check the choke circuit as Lowco suggested, that could certainly be it as well.
Old 07-28-2003, 08:47 PM
FFRacing's Avatar
As a rule of thumb, Yardpro hit it right on...but he didnt need me to tell him that! LOL
Another thing to check is the enrichener plunger...with age they tend to deform on the end, allowing extra fuel to enter when it shouldn't. Easy to check.
Old 07-29-2003, 09:38 AM
Thanks for the tip for the float level check, I've gotta stop by the dealership tonight to pick up some other parts so I'll ask them for the spec also.
Didn't get a chance to take the carb off last night, decided to go over the bike from the ground up to take an inventory first. Not bad, I did find that the boots comming off and going to the carbs are trashed and held (loosely) together with duct tape, those'll need to be replaced before I can do much more trouble shooting.
Atleast now I've got some direction. And thanks for the welcome, I'll do a follow up post once I get her runnin up to par.
sff.
Similar Threads for: Fouled Plug
Really fouled plug? spartanbiker_117 2-Stroke Motorcycles - Honda 16 11-25-2007 10:22 PM
What happens when a plug is fouled? mbogosia 2-Stroke Motorcycles - Yamaha 2 08-05-2007 07:04 PM
YZ250 spark plug fouled after every half tank YZ250 kid 2-Stroke Motorcycles - Yamaha 9 07-14-2004 01:50 PM
FOULED UP PLUG!??? TRXman86 ATV/UTV - Yamaha 10 03-21-2004 11:36 PM
Dah question- fouled plug rjmorel Vintage Riding 4 12-15-2003 11:19 AM
