| Portal | Forums | ATM! Online Store | Photo Gallery | Moto Garage | RSS Feeds | ATM! Link Directory | Today's New Users |
Crf bog...This is a discussion on Crf bog... within the 4-Stroke Motorcycles - General Discussion forum, part of the 4-Stroke Motorcycle Forums category; Well guys i need some advice on this bog on a thumper...Well i timed my squirt and its squirting for ... |
| Well guys i need some advice on this bog on a thumper...Well i timed my squirt and its squirting for 1 sec...I think its hitting the slide some when it squirts which aka causes the bog when u twist the trottle fast..my question is does turning the timing screw in or out make it squirt later? ive got the bog down to just alittle now.. |
| now dont u guys all reply at once now... |
| What screw are you refering to as the "timing screw"? The duration of squirt is determined by the leak jet. |
| It says on the paper that came with my new accelerator pump cover to re-set the pump timing to 3/32 the screw inside the push in pull meganisem cover it controls the diaphram... |
| Is this a 2006 carb by any chance? They are JUNK on the 250F's. Most of them required all kinds of work. |
| No this is a 2007 CRF 150R |
| I was talking to a guy about these yesterday, there is a timing screw that adjusts the fuel timing squirt into the carb on the 150's, if it's hitting the slide then you will be getting a bog, i would try a quarter turn at a time and see what happens. Just keep note of where you started from so you can go back to it if you get it all wrong. |
