Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 4-Stroke Motorcycle Forums > 4-Stroke Motorcycles - General Discussion
buying a used 250 four-stroke
This is a discussion on buying a used 250 four-stroke within the 4-Stroke Motorcycles - General Discussion forum, part of the 4-Stroke Motorcycle Forums category; I was wondering if buying a used 250 four-stroke is a good idea. How can you tell if it has ...
Old 03-30-2004, 04:01 PM
1kx100's Avatar
Last Online: 07-25-2007 04:05 PM
grabit buying a used 250 four-stroke
I was wondering if buying a used 250 four-stroke is a good idea. How can you tell if it has been taken care of? What year is a good 250 four-stroke?
Old 03-30-2004, 04:04 PM
Thump_This's Avatar
Drama Queen #001
Default Re: buying a used 250 four-stroke
check compression. seals. ride it around. jump it and run! j.k.
Old 03-30-2004, 04:10 PM
1kx100's Avatar
how can you tell if they changed the oil and filters?
Old 03-30-2004, 05:27 PM
Deadeye's Avatar
That is tough to tell. If you are buying from the owner (not a dealer) you can sometimes throw out a general question like,” Is it expensive to change oil for the whole summer?” and “ How long does it take to change oil?”. Pay close attention to the answer they give and this sometimes tells a lot. If you can, look at the air filter and even remove it and feel for grit in-between the inlet and carb. Gab the top of the back tire and shake it from side to side to make sure the swing arm is tight. Check the fork seals, clutch, rear brake pads, and rear brake lever.
Old 04-03-2004, 02:21 PM
Looking at the cam lobes will tell you more than any question will about how well it has been taken care of lubricationwise. In the end it wont matter if he did change his oil (or didnt) if there has been accelerated wear due to other conditions. Scored or cams will discolored wear areas can signal that kind of abuse.
Old 04-03-2004, 02:23 PM
Make that "cams with"
Old 04-03-2004, 02:55 PM
LoKi's Avatar
Long Live the Goat
Last Online: 01-12-2009 06:29 PM
Just like buying anything used. You have to ask "why are you selling it?" Does it look like they've taken care of it, or is it thrashed? Look for leaks, ask about maintenance, and anything they've done to it recently. Make sure it fires right up and test it out. Nothing wrong with buying used. One persons misfortune can be another persons treasure.
Old 04-05-2004, 04:04 PM
berudd's Avatar
Last Online: 05-29-2007 08:25 AM
The outward appearance of the bike tells alot about the appearance of the innards. It it looks like it was not cared for then it probably was not.
Old 04-06-2004, 05:08 PM
Deadeye's Avatar
ossagp - People actually let you rip their bike apart before you buy it? I wouldn't let anybody touch my bike with a wrench until the check clears.
Old 04-29-2004, 07:31 PM
Newf_Rider's Avatar
Last Online: 07-19-2004 10:32 AM
well im lookin for a new bike to get now to i have been lookin for 6 weeks and i cant find a good 4 stroke bike i just got to say dont buy the first thing u look at it
Similar Threads for: buying a used 250 four-stroke
Basic maintenance and checkover for buying used 2-stroke Evader 53 2-Stroke Motorcycles - General Discussion 3 03-19-2008 04:44 AM
So i'm buying a four-stroke... Blitz393 4-Stroke Motorcycles - General Discussion 8 12-10-2007 02:28 PM
So I'm buying my first bike...a 250 2 stroke...or should I get a 4 stroke...? SCARFACE1 2-Stroke Motorcycles - General Discussion 42 10-27-2005 05:44 AM
Finally, buying a 4 stroke CRacer 4-Stroke Motorcycles - General Discussion 55 06-22-2004 03:23 PM
buying a used four-stroke: Risky? 1kx100 4-Stroke Motorcycles - General Discussion 9 03-31-2004 10:37 PM
