V Force Reeds or Boyesen Reeds
This is a discussion on V Force Reeds or Boyesen Reeds within the 2-Stroke Motorcycles - General Discussion forum, part of the 2-Stroke Motorcycle Forums category; Hey i was wondering which to get, VForce reeds or boyesen reeds. Which is better? And why? Also i heard ...
Old 06-29-2004, 06:54 PM
mattdcs's Avatar
TwO StrokeS OwN
Last Online: 06-24-2006 02:59 PM
Also i heard you have to rejet your carb, if you install new vforce reeds. Is this true?
And is there any directions that tells you how to do it and what to do?
Old 06-29-2004, 07:03 PM
2kHondaCR500R's Avatar
Bigbore Pingers For Life!
Last Online: 03-02-2010 11:03 PM
Default Re: V Force Reeds or Boyesen Reeds
Edit, thought you said reed valve. Just go by the manufactures recommendations on the reeds, and I don't think you can go wrong with either brand myself.
Old 06-29-2004, 07:17 PM
Roostman's Avatar
"Roostman, lays an egg!"
Last Online: 04-17-2009 02:59 AM
Im partial to Boyesen and have used them with great results for the last 20+ years on all of my bikes. The VForce are probably just as good. I wouldnt touch your jetting if your bike is running good now. Put the new reeds in and see how it runs. There are lots of variables when it comes to jetting. If you find that after installing new reeds that your bike is off a little, then play with the jetting. Good luck.
Old 06-29-2004, 07:20 PM
Red Rocket #13's Avatar
I Cruise On My Red Rocket
Last Online: 10-03-2005 08:22 PM
personaly i choose v-force. I have tried both on my 125 and the v-force not only helped more (ever where) over the boyesen but it lasted until i sold it. The boyesen craped out maybe 5 months after i got it, so replaced it with a delta. Go Mototassinari!
Old 06-29-2004, 08:02 PM
mattdcs's Avatar
TwO StrokeS OwN
Okay thanks vforce 3 reed valves it is!!!!! But i found this at the boyesen web site.
Each Boyesen RAD Valve is unique - tailor made to that model, year and displacement. While other aftermarket valves might change flange sizes or bolt patterns, they're basically generic - and require you to irreversibly cut your intake boot to install it! But with the RAD Valve, there are no compromises in power, no modifications.
So does this mean i have to cut my V Force reeds when i get them??
Old 06-29-2004, 08:05 PM
psycho393's Avatar
I got DUALS
Last Online: Today 04:52 AM
no you don't have to the reeds. What that is saying is that the reeds that you get for your bike are the same dimensions as those that may go into other bikes where as Boyesen claim to be slightly different and made exact for each specific model.
Old 06-29-2004, 08:20 PM
If you do the V Force Delta 2 "Reed Valve" or Boyesen "Rad Valve" you will have to rejet. If you only buy Stock replacement reeds for your factory reed valve, then I don't think you will need to rejet. Also, I suppose if you don't want to modify anything when buying a whole new reed valve assembly, then buy the Boyesen Rad Valve since it says it doesn't require modifications.
Old 06-29-2004, 08:24 PM
mattdcs's Avatar
TwO StrokeS OwN
This guy says i shouldnt touch my jetting, even if i put them in. Yet you 2khonda say i have to... So cruiser v force reed valves are fine?
Old 06-29-2004, 08:47 PM
Mecrazyperson's Avatar
Banned
Last Online: 05-12-2008 03:26 PM
V-Force Is what I run, took me a little while to get the jetting perfect but its worth it in the end. Nothing against boysens, they make some great products.
P4L
Old 06-29-2004, 08:51 PM
I think what he's saying is put in the V Force Delta 2 reed valve and fire it up to see how it's running before you make changes, then jet as needed. :
Old 06-29-2004, 08:58 PM
Scroll down to jetting: [Only registered and activated users can see links. ]
Old 06-29-2004, 09:03 PM
Here is a link on Boyesen site, click download and see jetting in top of the pdf. [Only registered and activated users can see links. ]
This has a list of jet changes too: [Only registered and activated users can see links. ]
Old 06-29-2004, 09:12 PM
mattdcs's Avatar
TwO StrokeS OwN
Thanks 2kHondaCR500R!
Old 06-29-2004, 09:16 PM
mattdcs's Avatar
TwO StrokeS OwN
WoW i can't do that!!!! I would have to take it in for them to fit it.
Old 06-29-2004, 09:22 PM
mattdcs's Avatar
TwO StrokeS OwN
Why are the boysene instructions so much easier than the Vforce reed installation instructions. The boysene is take out the stock and put the new in. The vforce is cut plastic off with a saw and keep stock valve in there then put the vforce in there?????????????Damn
Old 06-29-2004, 09:24 PM
Roostman's Avatar
Dude, I have the Rad Valve on my bike that I put on, and no, I didnt and havent had to touch my jetting, and yes it works great with a very nice difference in power delivery (they also pit the Boyesen against the VForce on the dyno and guess who is on top?). This is my experience talking not my opinion, do with it as you will. I too didnt like the idea of cutting my intake boot for the V Force setup and went with the Boyesen. The Boyesen is also investment cast aluminum vs. PLASTIC like the V Force.
Old 06-29-2004, 09:32 PM
Give me a week and I'll take pictures and let you know how difficult the V Force Delta 2 reed valve install is on my CR 500R. Well, since the 4th of July it might take an extra day to get here, but as soon as it does I will let you know.
Old 06-29-2004, 09:46 PM
Not picking apart your post so don't take this wrong, but lots of car parts and bike parts are made out of plastic. Even the stock intake on my Mustang GT is and I had no problems out of it, so how is this a bad quality to have on the bike? I also don't think trimming that intake boot is anything to be concerned about. It looks easy to me, and I'll have full details on it when mine comes.
Old 06-29-2004, 10:13 PM
mattdcs's Avatar
TwO StrokeS OwN
[QUOTE]Originally posted by 2kHondaCR500R
[B]Not picking apart your post so don't take this wrong, but lots of car parts and bike parts are made out of plastic. Even the stock intake on my Mustang GT is and I had no problems out of it, so how is this a bad quality to have on the bike? I also don't think trimming that intake boot is anything to be concerned about. It looks easy to me, and I'll have full details on it when mine comes.
So do you still have to get yours then you are going to do the pictures?
Old 06-29-2004, 10:37 PM
I just ordered it Monday, so I guess with UPS ground it will be here in about five business days. If you can hold out until then, I'll have pictures of the install.
Similar Threads for: V Force Reeds or Boyesen Reeds
Jetting 2000 yz250 with Boyesen reeds yamahootin 2-Stroke Motorcycles - Yamaha 2 01-19-2009 07:36 AM
Boyesen Reeds kawaboy22 2-Stroke Motorcycles - General Discussion 5 04-11-2008 06:23 PM
V-Force 3 Reeds redryder250 2-Stroke Motorcycles - General Discussion 4 10-26-2004 07:39 AM
Boyesen Reeds and Jetting? kx_guy86 2-Stroke Motorcycles - General Discussion 7 05-26-2004 11:31 PM
v-force reeds okayguy General Discussion 2 02-01-2004 09:08 PM
