Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 2-Stroke Dirt Bike Forums > 2-Stroke Dirt Bike - General Discussion
RM 250 bogging ?
This is a discussion on RM 250 bogging ? within the 2-Stroke Dirt Bike - General Discussion forum, part of the 2-Stroke Dirt Bike Forums category; ok guy,s/gurl,s i have a 1999 RM250 it runs great but my weight has alot to do wiht the power ...
Old 12-03-2007, 08:17 PM
nathan's Avatar
Last Online: 02-04-2009 10:43 AM
Default RM 250 bogging ?
ok guy,s/gurl,s i have a 1999 RM250 it runs great but my weight has alot to do wiht the power im 6/2 and 260 pounds the bike is a beast when im got it winded a bit its got a lot of top but how can i gain a lot lof bottom and still maintain the top i have..thanks guys
Old 12-04-2007, 08:03 AM
Last Online: 02-23-2010 04:46 AM
Thumbs up Re: RM 250 bogging ?
hi nathan
the best way for you will be to experiment with different gearing ie
if your running a standard sprocket set up ie 13 front 49 back
try a 12 on the front its cheaper than the back if you have a spare say 51 tooth try it on the back.
do this try it out and as i say experiment.
dont go down the jetting road it can make things worse.
hope this helps cheers jambo
mufc will rule the world one day.lol
Old 12-06-2007, 12:12 AM
nathan's Avatar
Default Re: RM 250 bogging ?
hey thanks fer the reply i run a 12/50 and i dont wonna go any slower than that .that was the first thing i done when i got the bike im guesing a FMF fatty pipe and a shorty is next then reeds thanks
Old 12-21-2007, 04:41 AM
Jethro's Avatar
Last Online: 07-25-2010 02:12 AM
Check that the powervalve pre-tension spring is set correctly (I've got a '94 RM250 and from memory I think the factory spec is 180 degrees clockwise from zero, check your manual to be safe though). You may find that the valve is opening too early if not set to the correct tension, this would affect the power at lower revs.
Old 12-21-2007, 07:46 AM
nathan's Avatar
yea its right its how its supost to be i just need more power i guess a pipe and reeds is the next thing thats goin on so ill see if that help
Old 12-21-2007, 07:49 AM
Jethro's Avatar
In that case I'd go for a Boyesen Rad cage and a Fatty, but fit them at the same time so that you only have to re-jet the thing once...
Old 12-22-2007, 09:03 PM
nathan's Avatar
ok ill do it when i can aford it next thanks fer the input
Old 12-22-2007, 09:30 PM
Shoei_391's Avatar
Last Online: 04-13-2011 03:45 PM
like others have said, i would get a fmf fatty, and i would change my gearing.
but with doing that you would lose some up top
Old 12-23-2007, 11:04 AM
nathan's Avatar
yea im prepaired to loose some top i just need more bottom so when i ride in the moutians cause thats about all i do around here
Similar Threads for: RM 250 bogging ?
bogging out motocrossjake12 4-Stroke Dirt Bike - General Discussion 3 06-13-2007 05:12 AM
Bogging yz rider125 2-Stroke Dirt Bike - Yamaha 11 02-25-2007 02:27 PM
CR 125 bogging on low-end Forgiven96 2-Stroke Dirt Bike - Honda 20 02-25-2007 09:20 AM
Bogging Out!! Matt3126 2-Stroke Dirt Bike - General Discussion 8 05-25-2006 08:30 AM
Bogging Down kd2310kd ATV/UTV - Yamaha 8 03-22-2006 02:53 PM
