Reeds?
This is a discussion on Reeds? within the 2-Stroke Motorcycles - General Discussion forum, part of the 2-Stroke Motorcycle Forums category; What Do Bad Reeds Do? What Are The Simtoms...
Old 09-01-2004, 07:46 PM
Last Online: 09-08-2004 02:20 PM
Reeds?
Old 09-01-2004, 09:50 PM
monoshock's Avatar
My powerband is broke!
Last Online: 08-26-2006 06:57 PM
Default Re: Reeds?
Hard starting, loss of power, erratic idle.
Old 09-02-2004, 01:05 AM
I've been RM-Zedded
Default Re: Reeds?
sputtering at higher RPM's
Old 09-02-2004, 01:27 AM
2fun's Avatar
Super Sonic Moderator
Last Online: 03-18-2010 01:02 AM
Thumbs down Re: Reeds?
Can also do motor damage (from what I understand) if a piece of the reed material breaks off, and gets sucked into the motor!
Old 09-02-2004, 01:29 AM
2fun's Avatar
Thumbs up Re: Reeds?
By the way Lifeflight4, I see this is your first post.
Welcome to ATM!
Hope you stick around and post often!
Lots of great people here to help out!
Old 09-02-2004, 06:54 AM
Aussie@Down Under!
Last Online: 01-22-2006 08:02 PM
Default Re: Reeds?
Hey lifeflight4 I just changed mine in my KTM. Noticed the outer corners starting to fray (break up). Dont know if they where affecting the way it ran but better to get to it before damage done. A read is basically a inlet valve if it has a leak you can lose compression.
Old 09-02-2004, 02:54 PM
Reeds?
ok my engin has some sort of raddle to it and its hard to start and i have to push start it to get it started and yes when i rev it up its like to wont go any more ad it dont sound like a 2 stroke.
what is the simtom on low compression
Old 09-02-2004, 06:38 PM
zuki's Avatar
Last Online: 03-05-2010 01:02 PM
Default Re: Reeds?
hard to start...loss in engine power. When I replaced my top end I was at 109 psi. Might I suggest that you go out and buy a compression gauge. What kind of bike are you talking about??
Old 09-02-2004, 08:30 PM
Default reeds
98 kx80
Old 09-02-2004, 08:50 PM
monoshock's Avatar
Default Re: Reeds?
When's the last time it had a top on it?
Old 09-03-2004, 04:26 AM
Default Re: Reeds?
i dont know i just bought it for $450.00 but the problem might be the reeds but im all so thinking it the top end
Old 09-07-2004, 09:55 PM
monoshock's Avatar
Default Re: Reeds?
Pull the reeds first and take a look. It's a lot simpler than doing a top end.
Old 09-08-2004, 05:22 AM
Default Re: Reeds?
it does not have compression so it is the top end?
Old 09-08-2004, 05:25 AM
I've been RM-Zedded
Default Re: Reeds?
Absolutely.
Old 09-08-2004, 05:29 AM
Aus_Rider_22's Avatar
Mod From Down Under
Last Online: 03-14-2010 10:40 PM
Default Re: Reeds?
While your in there, check the rod for up and down movement. It's a 98 so it could be due. Good luck and let us know how u go
Similar Threads for: Reeds?
When reeds go bad? daveythewavey19 2-Stroke Motorcycles - General Discussion 19 01-18-2007 01:48 AM
Reeds redrider4 General Discussion 4 02-16-2006 01:50 PM
Anyone??? reeds vs. rad valve reeds mattreicho 2-Stroke Motorcycles - General Discussion 5 09-09-2004 10:26 PM
V Force Reeds or Boyesen Reeds mattdcs 2-Stroke Motorcycles - General Discussion 54 07-11-2004 10:38 AM
reeds dirtracer_2000 2-Stroke Motorcycles - Yamaha 1 02-25-2004 05:40 PM
