noob here with a clutch ?This is a discussion on noob here with a clutch ? within the 2-Stroke Motorcycles - General Discussion forum, part of the 2-Stroke Motorcycle Forums category; I have a 98 cr 125 that I just got that I had to replace the top end. I have ... |
| I have a 98 cr 125 that I just got that I had to replace the top end. I have adjusted the clutch lever all I can and it wont engage , so I have taken off the cover and the outer plate is moving when I pull in the clutch but the inner plates will not move with it. I can move the plates with my fingers pretty easy but sometimes they stick togeather but even with all the plates moved the clutch is still disengaged. I used bel ray 85w gear saver, is there any other oil yall would recomend and would wrong oil cause this to happen. Im at the point where im about to set this thing on fire |
| Welcome to |
| thank you, and I got the clutch fixed by riding the bike and pulling in the clutch lever and slamming on the rear break. Doing this will break lose the inner plates from the outer plates |
| Another Noob from So Cal | AgentSmith | Member Introductions | 14 | 06-10-2009 09:11 PM |
| noob, here..... | ccstud17 | 2-Stroke Motorcycles - Yamaha | 2 | 10-12-2008 03:16 PM |
| Noob Here | bronc3 | Member Introductions | 12 | 03-11-2008 09:38 PM |
| MO Noob | blueyami757 | Member Introductions | 7 | 12-24-2007 12:17 AM |
| noob=me | YamahaP8ntbal52 | 4-Stroke Motorcycles - General Discussion | 9 | 04-03-2006 04:49 PM |
