leak testerThis is a discussion on leak tester within the 2-Stroke Motorcycles - General Discussion forum, part of the 2-Stroke Motorcycle Forums category; Ok I build the leak tester. Now, was it that the engine had to hold six pounds for six minutes ... |
| Ok I build the leak tester. Now, was it that the engine had to hold six pounds for six minutes or it could only loose six pounds in six minutes. Any way I put six pounds in her and she slowly leaked out. You could actualy see the needle move seemed like a pound a minute or so. The only possible exit for the presure I have located so far was the breather hose for the gear box. It would bubble soap up some what. Is the right crank seal done? If it is, is it a huge job on a cr? I have done it on a Yz before and I assume its similar. Pull side case, pump, ect. |
| $17 Leak Tester (2-Stroke) | Faded | 2-Stroke Motorcycle Knowledge Base | 25 | 09-23-2009 09:03 AM |
| 2002 RM 250 Problems continue/ leak down tester picture needed | Fluffyhead | 2-Stroke Motorcycles - Suzuki | 7 | 12-08-2008 10:23 PM |
| Leak down tester... | CaRdinalFan450 | General Discussion | 2 | 10-27-2005 12:22 PM |
| Leak Tester Build Question | Yamadog | 2-Stroke Motorcycles - Honda | 17 | 01-18-2005 01:25 PM |
| leak tester | Yamadog | 2-Stroke Motorcycles - Honda | 2 | 01-11-2005 01:39 PM |
