HELP bike running fine, landed from jump, died, and wont start now!!! HELP
This is a discussion on HELP bike running fine, landed from jump, died, and wont start now!!! HELP within the 2-Stroke Motorcycles - General Discussion forum, part of the 2-Stroke Motorcycle Forums category; hey i have a 2002 cr125 and i was hitting one of my jumps and i revved it up real ...
Old 04-14-2006, 09:58 AM
lilsuperman's Avatar
Last Online: 07-14-2006 01:11 PM
Default HELP bike running fine, landed from jump, died, and wont start now!!! HELP
hey i have a 2002 cr125 and i was hitting one of my jumps and i revved it up real hard in the air to bring the fr wheel up and when i landed it died, i thought i just fouled a plug so i swapped it out and nothing. I cleaned the air filter, reset the floats, and made sure the reeds werent cracked or sticking..
When i try to kick it over it starts to BARELY prrr and then it makes a popwoosh sound and thats it. And it is hard to even get it to do that. The compression seems alright but im not sure, i put some oil in the cylinder to see if that would help seal it up to get it started but that didnt help either.
I HAVE NO IDEA what to check now, i took the silencer off to check the packing and it seems fine, i was in the process of taking off the header but i dont have the right tool...
HELP!!!
Old 04-14-2006, 10:42 AM
Last Online: 06-29-2007 12:12 AM
Default Re: HELP bike running fine, landed from jump, died, and wont start now!!! HELP
Check the engine kill button and wireing for it. You could have landed hard and lossened or pulled the wiring.
Then disconnect pull the spark plug connect the plug and hold it against the cylinder. Push the kicker and see if your plug sparks. This will test your electric system and put you on the right track to see what next to test. Good luck
Old 04-14-2006, 11:01 AM
crazyrydermx's Avatar
Don't abbrev.
Last Online: 08-28-2006 03:36 PM
pinned throttle in air, landed, bike died, wont start!! HELP
^^^Did you make sure and do EVERYTHING from the first time you posted this thread?
Have you actually checked the compression? You say it seems alright but you can't tell unless you have actually checked it. I can't really help you until you check the compression...because it is seriously sounding like an engine problem to me.
Old 04-14-2006, 11:16 AM
Satch0922's Avatar
stuck float?
Old 04-14-2006, 11:31 AM
well i did check the spark like you said hardcore and it works good so i dont think it can be electrical.
float works good satch0922
i have checked all the simple things, plug, filter everything checks out
THE ONLY THING i have not checked is the compression, mine was always a little weak it seemed like compared to my bros 01 kx125. His kick start is much harder than mine. and even tho my bike has motor work done and better engine parts and runs on race fuel, it seems like his has more bottom end pwr by far!! i just rebuilt the top end with wiseco piston/wring kit no more than 10-20 hrs or riding ago... i guess i will be stopping at walmart here soon
Old 04-14-2006, 11:42 AM
Similar Threads for: HELP bike running fine, landed from jump, died, and wont start now!!! HELP
i need help my bike wont start speeddemon 2-Stroke Motorcycles - Suzuki 13 06-23-2007 04:20 PM
dont no why it died and wont start RideToDieCR 2-Stroke Motorcycles - Honda 16 04-16-2007 08:09 PM
pinned throttle in air, landed, bike died, wont start!! HELP lilsuperman 2-Stroke Motorcycles - Honda 21 03-04-2006 09:17 PM
Help engine problems..bike wont keep running VStar 650 CaRdinalFan450 General Discussion 0 11-19-2005 10:43 AM
Bike Wont Start Need A Little Help Boardfox 2-Stroke Motorcycles - General Discussion 4 03-09-2005 06:52 AM
