EZ pull clutch
This is a discussion on EZ pull clutch within the 2-Stroke Motorcycles - General Discussion forum, part of the 2-Stroke Motorcycle Forums category; I did a lot of searching around and didn't find much on this. I'm wondering if anyone has used the ...
Old 02-20-2008, 01:10 PM
Last Online: 05-13-2008 10:22 AM
Default EZ pull clutch
I did a lot of searching around and didn't find much on this. I'm wondering if anyone has used the MSR or Moose ez pull clutch levers and systems. They say they are for all bikes. One is for the lever and perch, the other has to do with you cable and linkage.
here are some links.
Old 02-20-2008, 01:28 PM
Last Online: 03-10-2008 02:18 AM
Default Re: EZ pull clutch
The moose ez pull lever is great. I have been running it on all my bikes for over a year. The moose system that connects inline is junk and will break in no time.
Old 02-20-2008, 08:05 PM
Cool, is the pull easy enough to use a shorty lever?
Old 02-21-2008, 09:25 AM
Last Online: 10-24-2009 06:26 PM
I use the MSR easy pull clutch with the shorty lever and absolutly love it! My fore arm is much happier at the end of the day also. Helps to reduce arm pump and fatigue. Now I don't like riding my sons 250 because his does not have one.
Old 02-21-2008, 10:40 AM
krzywhiteboy's Avatar
Wheelie Master
Last Online: 09-20-2009 02:42 PM
You can always just drill another hole in the lever for the cable to go into, so that you can get more mechanical advantage on the pull. Makes it super easy to pull a lever if you do that.
Old 02-21-2008, 11:35 AM
dhighlan's Avatar
There Can Be Only One
Last Online: 12-02-2008 10:00 AM
I have used the in line easy pull for two years with out any suck glitch. I can't even imagine how it could break to be honest. It is a lever with two separate connection points for more leverage.
Old 02-22-2008, 09:08 AM
thanks guys, im gonna try the msr lever and see what happens.
Old 03-19-2008, 02:30 AM
I bought the MSR EZ pull and installed it. Seems to run smooth. I only have to pull it in half way. My question is, with the clutch cable being pulled farther being on the furthest hole is the clutch enganged slightly at all times.
Old 03-19-2008, 02:54 AM
nathan's Avatar
Just Let Me Hold It Wide
Last Online: 02-04-2009 12:43 PM
what kinda bike did u put it on and did u use the same clutch cable
Old 03-19-2008, 05:39 AM
the_privateer's Avatar
Last Online: 11-18-2009 05:09 AM
not if its adjusted correctly
Old 03-19-2008, 06:23 AM
dhighlan's Avatar
My clutches are engaged fully all the time, that is unless I pull in the clutch. You just need to make sure it disengages when pulled and fully engages when released with at least a dimes with of play between perch and lever.
Old 03-19-2008, 10:35 AM
The easiest pull is going to be in the hole closest to the pivot point.
Old 03-19-2008, 10:40 AM
dhighlan's Avatar
I would think it would be the one furthest from the pivot? Leverage principle-further from the fulcrum.
Old 03-19-2008, 11:50 AM
Your leverage is best when the fulcrum is closer to the object being levered.
Like using a prybar to pull a nail. The fulcrum is right next to the nail. Not farther down the prybar's length some where.
Old 03-19-2008, 12:04 PM
dhighlan's Avatar
Agree with the statement fully just I have the Moose and it works from the side you pull from not the side being pulled. I guess the MSR is different in that respect.
Old 03-19-2008, 03:28 PM
Its on a 97 kx 125, same cable.
I have it on the hole closest to the handle bar, that seems to work the best, but I just checked it and I do have to give it some slack to give a bit more play.
Old 03-20-2008, 07:58 PM
Moto man26's Avatar
Last Online: 02-23-2009 07:16 PM
Hi, I been reading this thread, and saw krzywhiteboy's comment about drilling another hole in the clutch lever to make it much more easier to pull it in... I would be interested in trying this trick... Because the clutch on my bike is kind of hard... But can you please tell me where I have to drill the hole... If you have any pictures, or just a explanation, it will be appreciated. Thanks!!
Old 03-21-2008, 08:37 AM
Wheelie Master
I don't have any pictures of this but I can explain it. It is a trick that my dad taught me when I was a kid. Basically you just drill a second hole a bit further out than the stock hole. Find a drill that..........ehhhh nevermind when I get home from work tonite I will pull the lever off of one of my old bikes and take a picture with my phone. It will explain everything.
Old 03-21-2008, 10:33 AM
Moto man26's Avatar
Hey, thanks alot krzywhiteboy!! But will drilling a hole weaken the lever? Anyways, thanks again!
Old 03-21-2008, 11:17 AM
Wheelie Master
Some people have said that this could weaken the leaver, I however do not think so. I have been doing this as long as I have ridden which is about 20 years and my dad has done it on everything from Harleys to his Jawa, it was his Jawa in the late 60's or early 70's that he started doing it on. When he passed last year and his club was presenting me with his Harley I noticed that those levers were that way too, so theres about 40 years of doing it with no broken lever. I have broken numerous bones in crashes over the years and lots of levers but none in that spot. My assistant was telling me that he saw a how to on a different forum. I will search over there and maybe I can find it.
Similar Threads for: EZ pull clutch
yet another hard clutch pull jemmrich General Discussion 1 02-21-2008 07:26 PM
tough clutch pull HLD 2-Stroke Motorcycles - Honda 9 06-22-2005 09:08 PM
Clutch pull hard... huffdaddy70 4-Stroke Motorcycles - Yamaha 22 05-30-2004 08:35 PM
E-Z pull clutch system hiett_431 4-Stroke Motorcycles - General Discussion 3 05-21-2004 08:00 AM
E-Z Pull Clutch BlueBlur426 4-Stroke Motorcycles - Yamaha 1 12-19-2003 03:12 PM
