Crank SealThis is a discussion on Crank Seal within the 2-Stroke Motorcycles - General Discussion forum, part of the 2-Stroke Motorcycle Forums category; Is there a way to check if a crank seal is bad? About how much tranny oil should come out ... |
| Is there a way to check if a crank seal is bad? About how much tranny oil should come out when i drain it? What coler smoke would be put out if the seal is bad? It is a 96 KTM 250. Thanks marc |
| I've read that the exhaust is color white and smells "bad" or diffrent than usual. You shoul fill your crank up to the correct level, measure that amount and compare to the amount after a good ride. There should be no significant diffrence. Could start with that... RC |
| Thank you, i'll try the smelling thing, but not too much, could be bad for the brain cells... |
| All depends which crank seal is bad, ignition side, or clutch side. If the clutch side is bad, the bike will burn transmission oil, and you should be able to smell that. The ignition side will mainly just cause an air leak, my ignition side crank seal blew out on my RM 125, and I didn't notice a difference, until I took the flywheel off, and saw a tiny little drizzle mark of transmission oil. The new seal was only 3 bucks! |
| you could build or buy an leak down tester and test it for a bad seal. |
| what's the cheapest way to do that? |
| Thank you |
| RM 250 crank seal? | acw592 | 2-Stroke Motorcycles - Suzuki | 6 | 10-22-2007 04:13 AM |
| CRANK SEAL | michaelryan12 | 2-Stroke Motorcycles - Honda | 11 | 02-20-2006 10:33 AM |
| Crank Seal on a 97 CR-250 | XRMike | 2-Stroke Motorcycles - Honda | 1 | 03-22-2005 10:50 PM |
| Crank seal help | hardlydangerous | 2-Stroke Motorcycles - General Discussion | 2 | 09-17-2004 08:19 PM |
| Help I think I blew a Crank seal??? | junesauce | 2-Stroke Motorcycles - General Discussion | 8 | 04-05-2004 10:34 AM |
