cr 85 problem
This is a discussion on cr 85 problem within the 2-Stroke Motorcycles - General Discussion forum, part of the 2-Stroke Motorcycle Forums category; My 2003 cr 85 will start and idle fine. But if i get it moving unless its full throttle it ...
Old 11-03-2009, 01:34 PM
Last Online: 11-03-2009 02:24 PM
Default cr 85 problem
My 2003 cr 85 will start and idle fine. But if i get it moving unless its full throttle it will bog and then quit. when i get into the low rpm's thats when it will just die
Old 11-03-2009, 01:55 PM
I've been RM-Zedded
Last Online: Today 03:53 AM
Couple things.
It sounds jetting related, more than likely lean in the pilot circuit of your carb.
Have you tried turning your air screw in 1/2 turn? I suggest turning it all the way in first, counting the rotations so you know where it's at, when turning it back out 1/2 turn less to see if that helps.
You could also have some debris in one of the jets that's causing the bike to not get fuel too, which means you'd need to clean your carb internals.
Old 11-03-2009, 02:00 PM
MotoMan's Avatar
Floppy
Last Online: Today 08:39 AM
My money is here.
Similar Threads for: cr 85 problem
78 RM 250 C2 Problem danny_discus 2-Stroke Motorcycles - Suzuki 6 06-15-2009 10:44 AM
Problem Smyerss58 2-Stroke Motorcycles - KTM 2 10-28-2007 03:04 PM
big problem 99cr125rdr 2-Stroke Motorcycles - Honda 7 09-14-2006 04:53 PM
No first gear problem solved / now problem with PV Crazy 2-Stroke Motorcycles - Yamaha 2 07-10-2004 04:58 PM
Rim problem CRacer General Discussion 6 05-03-2004 06:22 PM
