could use some help plzThis is a discussion on could use some help plz within the 2-Stroke Motorcycles - General Discussion forum, part of the 2-Stroke Motorcycle Forums category; I recently got a 98 cr 250. When I rode it home I didn't notice any probloms but over the ... |
| I recently got a 98 cr 250. When I rode it home I didn't notice any probloms but over the weeks I started to when the bike warms up (not idling warmed up but rode warmed up) it has a idling problom it idles normal for a second then climbes up and surges. I also noticed that I can't ride ata constint speed you can hold it haif throtle and it'll speed up and slow down a lot I have heard crank seals and I have heard carb just wondering if any body has any ides |
| Surging is normally a tell-tale sign of a bad crank seal (or other intake tract leak or deficiency). Check your headpipe seal and seal collar, too. Intake leaks can come from the exhaust on a 2-stroke (reversion of exhaust gas, pressures. Long story). Scott |
| Well I'm going to the hardwear store now to make a tester for the bottom end but how do I test the header seal just by look our is their a way to test it like the bottom end |
| Visual is usually sufficient - I remember those older Hondas had a bad habit of breaking a seal collar at the cylinder. Something to investigate as I am not too up on the specifics of Hondas. Another way would be to seal the end of the pipe (remove silencer) and include the pipe in your leakdown test. Scott |
| Thanks I well look that over good but I was also wondering how much air if any is aload throu the power vale linkage ill pulled the cover cous I was getting excesive air throu the.crank breatheir so I pulled the cover and when I spary it with wendex it bubbls prety bad |
| If it's leaking through the power valve linkage, I had that same problem. Here is a link to that thread: Leakdown test help Once I greased and moly'd my linkage, my leak went away. |
| Thanks ill give that a try and see what happens. I'm going to chang my crank seals any ways since I'm in their. On a diffrnt note I noticed that I have a reed vavle that is out of specs could that cous any probloms that I'm experincing |
| A non-sealing reed could cause irratic idle, yes. Scott |
