Confused on "Energy Conserving" oil - yz 125
This is a discussion on Confused on "Energy Conserving" oil - yz 125 within the 2-Stroke Motorcycles - General Discussion forum, part of the 2-Stroke Motorcycle Forums category; Got my new (to me) 2000 yz 125 I'm getting running (new clutch). My manual calls for 10w30 motor oil ...
Old 05-30-2007, 12:02 AM
Malcolmv8's Avatar
00 YZ 125
Last Online: 08-23-2009 08:57 AM
Default Confused on "Energy Conserving" oil - yz 125
Got my new (to me) 2000 yz 125 I'm getting running (new clutch). My manual calls for 10w30 motor oil in the tranny. I thought I read on this forum somewhere that you should not use oils that have "Energy Conserving" on the back in that certification circle as there are additives in the oil that is not compatible with a wet clutch.
I went to wal-mart tonight and couldn't find a single 10w30 oil without that energy conserving stamp. I found some Rottella 15w40 without it but they didn't have it in 10w30.
Any guidance on getting some oil? I don't want to get the super expensive yamalube stuff if I don't have to as I plan on changing the oil frequently.
Thanks guys
Malcolm
Old 05-30-2007, 10:01 AM
triplendo's Avatar
Moto Enthusiast
Last Online: Yesterday 10:02 AM
Default Re: Confused on "Energy Conserving" oil - yz 125
Oil for motorcycles is a touchy subject. It seems simple to me, but try this link and decide for yourself. [Only registered and activated users can see links. ]
Old 05-30-2007, 10:28 AM
I like automatic transmission fluid in mine. It has worked good in my stuff since about 1970. I have a cr500 that I have owned since 1988 which has had almost nothing but ATF in it since then. Someone will be along before long (if tradition holds) and tell you that ATF causes transmissions to wear or "break". If you like the way your bike shifts on ATF (I prefer it), use it. Some like the F type better than Mercon or Dexronn, as it is just a little bit more agressive on the clutch grab.
I have used 15-40 in lots of 4 strokes which have the transmission and engine running on the same oil. It works just fine for them. It always seems a little on the "heavy" side for two strokes, as the oil doesnt thin as much, at least early on in the ride(s) since it isn't subjected to combustion heat, and cam action as the 4 stroke usage is. Your clutch may drag just a little bit more on startoff is all you will notice. Good oil at a good price, if you ask me.
Old 05-30-2007, 12:48 PM
Malcolmv8's Avatar
00 YZ 125
Thanks for that link. I had actually read that link a long time ago and forgot about it. I re-read it to refresh my memory.
Based on that and what else I've read on this forum I'm going to get the Rotella 15w40. The cool thing is my kids quad takes 15w40 too so I can use it there as well. I have been putting castrol 10w40 into my KLX 250 (2006) but after reading that link I think I'll switch it to Rotella 15w40 too.
Thanks guys
Malcolm
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads for: Confused on "Energy Conserving" oil - yz 125
Josh Strout AKA "Cody's Dad" Going "OLD SCHOOL" at the GMB Satch0922 GMB V 11 10-10-2006 08:50 PM
99' KX125 ""sneezing""/""Hic-up"" noise... zildjianxdrumme 2-Stroke Motorcycles - Kawasaki 6 04-14-2005 08:39 PM
CR250 "A" clyinder vs "B" cylinder. How to indentify. Mike[socal] 2-Stroke Motorcycles - Honda 6 03-10-2005 10:02 AM
What is energy conserving oil? AbsoluteZero General Discussion 3 04-25-2004 02:37 PM
vB.Sponsors
