carb helpThis is a discussion on carb help within the 2-Stroke Motorcycles - General Discussion forum, part of the 2-Stroke Motorcycle Forums category; hi, i dont really know anything about carburetors, like the jetting or what the jets are. can somebody help out? ... |
| hi, i dont really know anything about carburetors, like the jetting or what the jets are. can somebody help out? i dont know what jets to change depending on temperature, rpm range, etc. im just curious about cabr setup and the sizes of the jets. also, can i adjust the mixture screw on the side of the carb (mikuni) if my bike is bogging in a certain rpm range, or will that ruin a piston or what have you. i dont want to melt a hole in mine like a friend of mine did. |
| well its actually on my lt230, but i dont think it would matter. basically, whenever i try to give it throttle, it bogs way down like im drowning it, and the air/fuel screw is out as far as it can go so i was just wondering if i turned it in if it would make the bog go away, or at least lessen it. great link by the way, it helps a lot, thanks |
| What ratio are you mixing the fuel/oil at?Is the bike stock?Or does it have a pipe? |
| straight gas, stock, stock pipe, and i turned the screw two turns in and it went away, so thanks anyway. |
| I just went through the same problem with my yz250. I thought it was jetting but it turned out to be leaky crank seals. First I would take the Carb off and clean it and see if it helps. If not then I would check for air leaks. Head gasket/base gasket and then lower end seals. When I took my stator off the seal was hanging out of the case just sucking air in. Good luck |
| Flat Slide Carb vs. Piston Valve Carb | cr85racer24 | 2-Stroke Motorcycles - Honda | 1 | 09-20-2009 09:38 PM |
| carb top cap | nathan | 2-Stroke Motorcycles - General Discussion | 5 | 11-20-2007 11:32 PM |
| need carb help | quadrider32 | ATV/UTV - Yamaha | 4 | 02-26-2006 11:30 PM |
| carb help! | Squirrel | General Discussion | 1 | 08-11-2005 06:11 PM |
| '02 Yz 125 Carb Help | hydride90 | 2-Stroke Motorcycles - Yamaha | 7 | 04-20-2005 09:53 AM |
