Can I put a 250 2stroke motor on a 125 frame
This is a discussion on Can I put a 250 2stroke motor on a 125 frame within the 2-Stroke Motorcycles - General Discussion forum, part of the 2-Stroke Motorcycle Forums category; Basically I have a 2006 yz 125 that keeps breaking down, most of the time it is the clutch no ...
Old 08-18-2008, 03:46 PM
Last Online: 08-18-2008 03:46 PM
Usflag Can I put a 250 2stroke motor on a 125 frame
Basically I have a 2006 yz 125 that keeps breaking down, most of the time it is the clutch no its the piston. So I have decided to put in a new motor, I would like to put a 250 two stroke motor onto my 125 frame. Anyone know if this can be done.
Thanks
Ryan
Old 08-18-2008, 04:02 PM
ktm_cody_199's Avatar
Last Online: 02-24-2010 09:42 PM
Default Re: Can I put a 250 2stroke motor on a 125 frame
As far as I know the frame is the same,but as for your ignition,carb,and motor mounts you will need to replace your pipe.Check your dealer about your ignition and stuff.
Old 08-28-2008, 08:25 PM
Last Online: 03-05-2009 01:31 PM
I have a 2003 yz125 and happened to have a beat up 2003 yz25 frame in the garage. I just went in and put a 125 engine in the frame to see if it would fit and it is not even close. I don't know if the changes made to the 2006 make a difference or not, but the older bikes do not swap. you can get a frame off ebay for a couple hundred though and swap everything else.
you would need a frame and carb but I think everything else is an evenswap
Old 08-28-2008, 08:37 PM
racerfty's Avatar
premix sniffer
Last Online: 10-11-2009 09:41 AM
I checked the yamaha parts system for 2006 yz 125 and 06 250 the part numbers are different (125 5151099-001 and 250 5152209-001) This normally means something is different, dont know what but being it is a race bike and every once counts i am sure they would not build a frame to handle the under powered 125 and the powerful 250 to the same specs. But on the other hand i have see a 05 blaster with a 76 yamaha 400 bike motor in it, if there is a will there is a way, just with the alum frame, you can't use a torch to cut, or a normal welder to "correct" the frame if new mounts are needed.
Old 08-28-2008, 08:56 PM
dklassen's Avatar
Last Online: 03-15-2010 06:48 PM
I didn't think that late model YZ125's were unreliable. Yes, the top end needs replacement however if you do frequent maintenance and install a Hinson or similar clutch you should be able to ride the bike for quite a while between rebuilds. A 250 motor is the NOT answer to your problems.
Old 08-28-2008, 10:34 PM
Aus_Rider_22's Avatar
Mod From Down Under
Last Online: 03-14-2010 10:40 PM
dklassen is on the money a 250 will give you problems as well unless you keep up basic maintenance. What exactly are the piston problems?
Tags
125 frame 250 motor
Similar Threads for: Can I put a 250 2stroke motor on a 125 frame
places to get honda cr125 motor parts and motor rebuilt madmanwinkey 2-Stroke Motorcycles - General Discussion 3 02-04-2008 10:11 PM
'92 RM125 motor fit in '91 frame? Woody_YZF 2-Stroke Motorcycles - Suzuki 6 09-27-2005 04:04 PM
05 KX250 motor, YZ250 motor, what is the difference UnsafeHaven 2-Stroke Motorcycles - Kawasaki 2 09-19-2005 11:35 AM
450 motor in a 426 frame??? bluebyu 4-Stroke Motorcycles - Yamaha 8 03-19-2004 10:46 PM
250f motor.....this yamaha motor is bulletproof? broorda 4-Stroke Motorcycles - Yamaha 36 01-16-2004 08:11 PM
