1995 RMX 250 High Idle
This is a discussion on 1995 RMX 250 High Idle within the 2-Stroke Motorcycles - General Discussion forum, part of the 2-Stroke Motorcycle Forums category; I recently just took my carb off, apart and cleaned it. I fixed the old problem I was having but ...
Old 08-25-2008, 07:09 PM
Last Online: 05-22-2009 04:11 PM
Default 1995 RMX 250 High Idle
I recently just took my carb off, apart and cleaned it. I fixed the old problem I was having but now the bike has a High Idle, I did not touch the idle screw in the process of working on it so im thinking its the slide, Ive tried putting it in again and still the same thing. Do I need to make a adjustments on the throttle line? or on the carb end?
Old 08-25-2008, 08:17 PM
Default Re: 1995 RMX 250 High Idle
Make sure all the carb boots are sealed up tight and not leaking air. By cleaning the carb out you may have knocked something loose that was slightly plugging the idle circuit, so if the carb boots are not torn and tight and the throttle cable is properly installed and in spec for freeplay go ahead and tweak the idle to where it should be.
Old 08-25-2008, 08:56 PM
char393's Avatar
Incretacular!!
I may be way off base, but are you sure you didn't put the slide in backwards?
Old 08-25-2008, 10:07 PM
Its a possibility and I will check for that tommorow.
Could the throttle cable become stretched a bit from removing the slide? It took a little force to pull it out the first time.
I will also check for air leaks, Should I check both boots? Or just the one before the carb.
Old 08-25-2008, 11:31 PM
Im not quite sure how the idle works on this bike, Its most likely not in the manual do to a clear marking on the carb, It says that the idle is under the choke, But im not sure how it works, There is no screw or anything.
Old 08-26-2008, 08:21 AM
I would check both boots, air leaks can cause idle problems and can cause motor problems if serious enough. I'm not sure which carb that bike has, but a photo might help us figure out where the idle screw is. I know on some older Honda CR's you could twist the choke knob to adjust the idle. I would doubt you could stretch the throttle cable by pulling hard on it one time, but even if you did that would cause the idle to drop not raise. The cable or slide might be hung up somewhere, causing the high idle. Double check everything (cable routing, carb slide, carb boots, etc). and go from there.
Old 08-26-2008, 09:26 AM
Alright, Im gonna check both boots and cable routing, etc.
Will the slide even go in facing the wrong direction? I guess I will try flipping that around last.
Here is a picture of the carb, I had to edit it because my camera could not focus good enough.
It appears that you turn the choke but that was not really doing anything, But I may have not turned it enough so I will try that again as well.
Old 08-26-2008, 11:52 AM
Ahh, fixed the problem, the throttle cable had to be adjusted up front. Runs very good now that the carb has been cleaned out.
Old 08-26-2008, 07:33 PM
On that carb you adjust the idle by turning the choke knob, glad you got it fixed.
Similar Threads for: 1995 RMX 250 High Idle
2000 CR250 HIGH IDLE ctroger24 2-Stroke Motorcycles - Honda 5 12-12-2008 02:16 AM
2002 cr250 High Idle? kitsrider 2-Stroke Motorcycles - Honda 2 10-20-2008 10:10 AM
1995 CR250 idle surging morevert 2-Stroke Motorcycles - Honda 1 08-22-2008 03:28 AM
1995-97 rm 125 idle speed 92rm125 2-Stroke Motorcycles - Suzuki 11 04-11-2008 12:00 PM
HIgh idle on 04 YZ125? 04whyzee 2-Stroke Motorcycles - Yamaha 5 01-05-2006 04:46 PM
