04 yz250 wot problems
This is a discussion on 04 yz250 wot problems within the 2-Stroke Motorcycles - General Discussion forum, part of the 2-Stroke Motorcycle Forums category; Mike bike has started (suddenly) 'blubbering' really badly when I get on it. I check the powervalve and it seems ...
Old 08-06-2004, 10:55 AM
Last Online: 02-24-2005 04:47 PM
Default 04 yz250 wot problems
Mike bike has started (suddenly) 'blubbering' really badly when I get on it. I check the powervalve and it seems to be working ok. I don't think it is jetting because the bike worked fine before. I took the carb apart and everything is clean.
Clean air filter.
New plug.
The petcock is clear-- anything else?
Could it be the solenoid?
Old 08-06-2004, 11:33 AM
drman's Avatar
Fender B...reaker!
Default Re: 04 yz250 wot problems
Well, your jetting could be rich from air changes...when you say "before", was the climate different than it is now in your area?
Old 08-06-2004, 11:35 AM
drman's Avatar
Fender B...reaker!
Oh, have you set your float?
Old 08-06-2004, 11:40 AM
It's not the jetting-- the bike went from pretty good to terrible overnight.
I did set the float.. I set it to spec and now there is no gas in the bowl! I don't get how your are supposed to set the float hight without the tab pressing on the needle. The directions in the manual mention this... the floats were just resting on the top of the bowl when I first opened it.
Besides, would the float hight just suddenly go bad??
Old 08-07-2004, 10:24 PM
I think the CDI may be shot. The resistance on the cdi for the solenoid is reading 7M Ohms.... can anyone else get a reading off their cdi? the manual specifies .7 to 1 M Ohm but I am not completely sure if the manual is referring to the correct pins.
Similar Threads for: 04 yz250 wot problems
YZ250 problems...Do I need a new crankshaft? kc1399 2-Stroke Motorcycles - Yamaha 9 03-12-2009 09:07 PM
Just got an 89' yz250, ran into a couple problems... kc1399 2-Stroke Motorcycles - General Discussion 1 02-23-2009 07:07 PM
03 yz250 motor problems bfinck_90 2-Stroke Motorcycles - Yamaha 1 12-05-2008 09:06 AM
yz250 running problems... Moto man26 2-Stroke Motorcycles - General Discussion 11 07-06-2008 10:48 PM
01 yz250 heat problems spdfrek 2-Stroke Motorcycles - Yamaha 8 07-14-2004 04:10 PM
