Go Back   All Things Moto! Web Forums > Reviews - Organized Rides - Recreation Areas - Classifieds > Product Reviews > Accessories & Bling
Dr. D Hot Start Set Up
This is a discussion on Dr. D Hot Start Set Up within the Accessories & Bling forum, part of the Product Reviews category; If you own a Yamaha YZF thumper with the pull button hot start Get teh DR.D Hot start lever accessory. ...
Old 12-23-2002, 03:49 PM
Semper Fidelis
Talking Dr. D Hot Start Set Up
If you own a Yamaha YZF thumper with the pull button hot start Get teh DR.D Hot start lever accessory. I have had mine for three weeks now. The fabrication is first rate and installation is simple. Other thumper models may be available, check their website for availability.
Remove the existing hot start knob using a 12 mm open end wrench.
Insert the Dr.D hot start into the orifice and thghten the barrel down with the 12 mm open end.
I removed the left radiator shroud to route the cable up to the handle bars. Take the clamp off of the ffront brake perch and install the lever / button for the hot start in its place.
Check for free action of the hot start and reinstall the radiator shroud.
the design of the actuator lever keeps your hand off of the throttle while doing a hot start and it is spring loaded so it releases when you take your thumb off. No lean running because you left the hot start knob pulled off and no flooding from twisting the throttle. sest of all no bending over in the heat of competition to find the hot start.
You can order direct from Dubach Racing Development
or from most mail or internet accessories suppliers.
I have had no problems with mine and I recommend dealing with Doug and Gina most wholeheartedly.
Happy Roosting.
Bill :
Last edited by Florida 393; 10-01-2006 at 07:47 PM. Reason: Spelling errors corrected
Old 12-23-2002, 04:45 PM
Madman393's Avatar
ATM Founder
Last Online: 09-14-2008 11:43 PM
Default Re: Dr. D Hot Start Set Up
I too found the Dr. D. hotstart to be a godsend on my 02'. There is nothing quite as aggravating as tearing off in the heat of a race after a stall--only to repeat it as you left the hot start button pulled out and it stalled again!
Old 12-29-2002, 06:33 PM
dmp437's Avatar
Last Online: 11-16-2004 12:18 PM
One of the better mods I've done, makes life so much easier, especially since I'm running a Clarke tank now on the WR.
Dr. D also makes a Hot Start kit for the 03's also. The 03's come with one now, but it's on the "wrong side" (clutch side) where it interferes with the quick adjust clutch cable feature. It's about half the cost of the earlier bike's setup becuase I believe it uses the same stock cable.
Old 01-06-2003, 01:48 PM
egoallenpoe393's Avatar
never a back turner
Last Online: 09-23-2009 03:13 PM
One thing I found an issue with is that you really need to keep the routing clear from binding, otherwise it makes the thumb actuator hard to push.
One complain I do have though is the thumb actuator could be a tiny bit longer
Otherwise it was well worth the money
Old 01-06-2003, 10:16 PM
bluebyu's Avatar
Blue Traitor
Last Online: 09-30-2009 10:45 AM
i liked the drd hot start but wish it came with alittle longer cable.if it got pinched between the tank and frame turning my bar would pull it out causing a lean condition..
Old 01-06-2003, 10:50 PM
jmiakaike's Avatar
Moderatorus Dirtbikeus
Last Online: 03-04-2004 01:32 PM
another good hot start is the ty davis hot start.. no cable involved. a thick air tube runs from the handlebar, so no pulling of a cable.. works great.
james
Old 01-06-2003, 11:07 PM
bluebyu's Avatar
Blue Traitor
i thought the ty davis was for older bikes.
Old 01-06-2003, 11:35 PM
jmiakaike's Avatar
hmm not sure.. i put one an '01 426... has the red plunger style hot start... it said it fit all yz's... worth checking into..
James
Old 01-30-2003, 05:01 PM
Rockey's Avatar
How much are these?
Old 01-30-2003, 05:20 PM
bluebyu's Avatar
Blue Traitor
they are 89 bucks at the local shop.Well worth it imho.
Old 01-30-2003, 05:53 PM
jmiakaike's Avatar
blue.. beat me to it.. lol.
i paid $89.95 from zip ty..
their kit has you remove the hot start plunger, they give you a machined aluminum piece that you put in its place (line up the hole in the plug with the hole in the carb) attach the clear tubing, and mount the piece. very easy.
james
Old 01-31-2003, 08:32 PM
Rockey's Avatar
I should probably get the bike before I decide on the mods
Similar Threads for: Dr. D Hot Start Set Up
HOT START LTD EDT CRF250 4-Stroke Motorcycles - Honda 11 08-13-2008 08:28 PM
Won't Kick Start But Will Bump Start RoostRM125 2-Stroke Motorcycles - General Discussion 38 02-22-2008 06:06 PM
06 yfz 450 will not start razz711 ATV/UTV - Yamaha 8 10-23-2006 02:27 PM
Why won't it start? Oring 4-Stroke Motorcycles - Yamaha 1 08-17-2005 08:07 AM
Won't Start???!!! 83SuzukiRM250 General Discussion 15 01-19-2004 10:39 AM
