Yamaha Blaster Timing Degree Key
This is a discussion on Yamaha Blaster Timing Degree Key within the ATV/UTV - Yamaha forum, part of the ATV/UTV Forums category; Hey does anyone know how to install a 4 degree key for a 2004 Yamaha Blaster, where does it go? ...
Old 05-20-2007, 06:48 PM
Last Online: 12-05-2007 01:14 PM
flasher Yamaha Blaster Timing Degree Key
Hey does anyone know how to install a 4 degree key for a 2004 Yamaha Blaster, where does it go? Does anyone have one installed on there Blaster and is it good?
Old 05-21-2007, 09:31 PM
sandnap's Avatar
Last Online: 09-28-2009 09:39 PM
Default Re: Yamaha Blaster Timing Degree Key
It aligns the flywheel with the crankshaft. You need to pull the flywheel with a flywheel puller ([Only registered and activated users can see links. ] ) and you will see the key in a groove on the crankshaft. I would recommend getting a service manual and following the directions to remove the flywheel. I installed one several years ago on my 2k1 blaster and noticed a slight improvement on the low end.
Old 05-22-2007, 06:17 PM
wait the flywheel is on the left side of the Blaster right? once i screw off the black panel the fly wheel will be there?
Old 05-22-2007, 09:53 PM
sandnap's Avatar
That is correct. It is really a pretty easy job and should only take about 20 minutes if you have the puller. Just make sure to keep your eye out for the stock key when you remove the flywheel because there is nothing holding it in when the flywheel is not in place. If you need a manual you can find one in pdf format on the internet.
Old 05-23-2007, 02:43 PM
where does the fly wheel puller connect to to pull it off. Then once its off the stock key is there then pull that out and replace it with the new key right? Thanks man
Old 05-23-2007, 03:06 PM
crfjedi393's Avatar
Super Moderator
Last Online: Yesterday 10:13 PM
Okay, somebody please educate me here. How does a different Woodruff Key make a difference in performance? I have never heard of such a thing so don't think I'm nitpicking here. Just curious.
Old 05-23-2007, 07:01 PM
sandnap's Avatar
The puller has a threaded collar that screws into the flywheel and a center core that screws in against the crank shaft forcing the collar (and hence the flywheel) off of the crank shaft. Works similar to a gear puller. And yes that is the basic process.
I should mention that the nut that holds the flywheel on can be a bit of a pain to remove. An impact wrench will get it but if you don't have one you might want to put the quad in 3rd gear, back it against a sturdy garage wall, stand on the back tires and yank on it (a breaker bar works good here).
Old 05-23-2007, 07:06 PM
sandnap's Avatar
It is slightly offset thus advancing the flywheel (timing) 4 degrees which improves performance on the bottom end.
Old 05-23-2007, 07:19 PM
flasher Re: Yamaha Blaster Timing Degree Key
well that clears alot of things up. very good information. lol so once i get in there the last step should be pull the key off and put on the new key right? thanx man. lol
Old 05-23-2007, 08:42 PM
sandnap's Avatar
Yes, put the new key in and reassemble the whole thing.
Old 05-24-2007, 06:42 AM
thanx man i hope every thing goes well with the installation. lol
Old 05-24-2007, 08:02 AM
crfjedi393's Avatar
Super Moderator
I see.
Similar Threads for: Yamaha Blaster Timing Degree Key
yamaha blaster timing liminlime_2005 ATV/UTV - Yamaha 1 04-30-2009 05:30 AM
Yamaha Warrior Timing drman ATV/UTV - Yamaha 6 04-29-2008 01:32 PM
Timing For 1977 Yamaha tt500 darkblade Vintage Riding 4 01-14-2008 08:45 AM
Blaster Timing johncam25 2-Stroke Dirt Bike - Yamaha 2 12-27-2007 07:54 AM
need help timing an old yamaha eightball8890 ATV/UTV - Yamaha 2 12-20-2003 06:14 AM
