Go Back   All Things Moto! Dirtbike Forums > Dirt Bike - ATV - Suspension Forums > ATV/UTV Forums > ATV/UTV - Yamaha
Old 03-06-2007, 04:53 PM
Last Online: 12-05-2007 02:14 PM
Question Yamaha Blaster clutch adjustment.
I have a 2004 yamaha blaster and when i pull the clutch lever in and put it into first gear the bike jumps foward and if I give it gas it try's to go foward with the clutch lever in. Does anyone know how to adjust the clutch.
Old 03-06-2007, 05:22 PM
P1M P1M is offline
Last Online: 03-16-2012 03:55 PM
Default Re: Yamaha Blaster clutch adjustment.
Try warming up the quad for awhile before you put it in gear. Give the clutch and oil time to warm up. You want between 5mm and 10mm of free play in the clutch lever. "About the thickness of a dime" Also make sure you have oil in the gear box.
Old 03-06-2007, 06:35 PM
Semper Fidelis
Last Online: 01-15-2018 06:14 PM
Usflag Re: Yamaha Blaster clutch adjustment.
20Blaster04,
I moved this to the Yamaha ATV forum for the best coverage for a response. Thanks and welcome to ATM.
Bill
Ill try to warm it up and see if it has enough oil in the gear box, but I put on a new clutch cable and adjusted the top part perfect. I think it needs to be adjusted in the crankcase but I dont know how to do that. does any body know how to?
Old 03-08-2007, 12:45 AM
Last Online: 06-13-2013 04:37 AM
When I had mine (03) I made my clutch where I had to pull the lever all the way in before it would engage. I done this at the lever though. As far as adjusting at the case, there should be another adjustment screw/bolt almost like the one on the lever. I will take a look at some micro-fiche and double check though. What level is your gear oil at, and what kind do you use? I tried the basic YAMI lube and it didn't work right. To me anyway, so I bought synthetic oil and worked great! When you ride it, when good and hot, do you have any oil coming out near front of bike? There is an over flow hose just above the header pipe, pretty much right next to the stem. Do you notice oil all over it or is it clean? If so, there was to much in the case and it blew out. Mine had a tendancy to blow to much out and leave me short to lube everything up.
I'll get info on clutch soon...
Old 03-08-2007, 01:29 PM
I use PJ1 oil for it but i think i may have put a little to much.
Old 03-08-2007, 01:44 PM
Last Online: 11-14-2008 06:11 PM
uum, so what is it?the thickness of a dime, or 5 or 10 mm, that's a BIG difference....
Old 03-08-2007, 02:01 PM
P1M P1M is offline
OPPPPSSSSS my bad!!!!!!!!!!!!!!!! I meant a nickle!!!!!!!!!!!!!
Got change for a dime!
Old 03-08-2007, 03:24 PM
Wait how many quarts of oil goes into the crankcase of my blaster. I think i may have put to much.
Old 03-08-2007, 03:28 PM
I think you need to use a better oil....maybe amsoil or something
Old 03-08-2007, 03:32 PM
P1M P1M is offline
I believe it takes alittle less then a quart.... If you look on the engine case where the filler hole is it should say something like 650cc oil
Old 03-08-2007, 04:30 PM
w0w you guys are great i used diffrent oil and put 650 ccs in and it WORKS!!!!!!!!!!!!!! Thank's you guyz are the best!!!!!!!!!!! Now back to ridding. lol
Old 03-09-2007, 01:06 AM
Keep an eye on the "peep site" hole. If your oil becomes cloudy where you cant really see thru the hole, change it. I changed mine after about every 4-6 races. On normal days of riding in off season, about every 10-15 depending on weather. I just played it safe. No problem on th ehelp. It's what we are here for ...
but you know,
GET SOME
Old 03-09-2007, 04:37 PM
Im getting pics tommarow but where do I put them on the site and how.
Old 03-09-2007, 10:02 PM
If you have photobucket, its easiest to do it that way, or go to photogallery here at look for "UPLOAD PHOTO" and go that route. You could also send them to me aand I could post em if you like.
Old 03-10-2007, 05:24 PM
I put the pictures on
Old 05-13-2010, 09:07 PM
Last Online: 05-13-2010 09:08 PM
I have a 1999 yamaha blaster and i would like to know what are the 2 hoses coming out of my crank case for and where do they go? and where does the clear hose go to?
Old 08-15-2010, 07:51 PM
Last Online: 08-16-2010 05:03 PM
Default help
i have a 1996 blaster with a new clutch it will not engage or disengae not sure the bike starts up great in neutral but with lever pulled in it jumps and stalls when i put it in gear i tried the lever adj. and it dosent make a difference is there a lower adj. that i am missing
Similar Threads for: Yamaha Blaster clutch adjustment.
yamaha blaster clutch? shaunporn777 General Discussion 1 03-25-2009 12:14 PM
Clutch adjustment DRGSin393 2-Stroke Dirt Bikes - Kawasaki 34 07-06-2007 09:13 AM
Clutch adjustment DRGSin393 2-Stroke Dirt Bikes - Yamaha 11 01-06-2006 09:03 PM
Clutch Adjustment MotoMcGee General Discussion 5 11-06-2005 09:17 PM
Clutch adjustment lfendr 2-Stroke Dirt Bikes - Honda 4 02-11-2005 04:00 PM
