Yamaha Big Bear transfer case shifter cable lubing?This is a discussion on Yamaha Big Bear transfer case shifter cable lubing? within the ATV/UTV - Yamaha forum, part of the ATV/UTV Forums category; Does anyone on here have an older 350 Big Bear? I got some water in the range shifter cable on ... |
| Does anyone on here have an older 350 Big Bear? I got some water in the range shifter cable on mine, which resulted in it freezing (it was 22F here at the time) and jamming it in Low range. Once I warmed up the ATV in a garage, everything was fine. But I'll be needing to use this thing this winter so it being a garage queen is unacceptable. I was told that a little WD40 in the cable will fix it, but I can't quite see how to get to the cable to do it. Any suggestions? |
| Sorry, I am not of much help on this one. Hopefully some of the other guys can give you a hand on this one. |
| maybe if you just got a cable luber if that would work? if not that, try to undo the cabel from where it was frozen or near it, get a can of liquid wrench (works a little better then WD40) and try to spray it into the cable using the straw. if the spray is forced in there, it should work. i have done it to my clutch cable before and seemed to work fine that way. let me know if it dont work, ill try to think of something else |
| I believe they make a cable lube tool. Not sure if that would work or not. |
| I've got a cable luber tool. The problem is, I can't quite see how to get the cable off the shifter mechanism. I'm hoping to do it without having to spend two hours on disassembly so I can take 30 seconds to lube the cable. |
| It turned out to be water in the shifter mechanism and not the cable itself. I disassembled the shifter mechanism, sprayed it down with WD40 and then white lithium grease, reassembled it and it's now good as new. I left it out all night in the back of my truck (~22F) and it still shifted fine in the morning. |
| Good to hear you got it figured out. Sorry we weren't much help. That's just not too common of a problem, but next time someone has the problem we'll know. |
| That's why I posted the fix. Now this weekend I can use it to drag some logs for firewood. |
