Valve adjustment on the YFZ 450??
This is a discussion on Valve adjustment on the YFZ 450?? within the ATV/UTV - Yamaha forum, part of the ATV/UTV Forums category; Ok, I was reading another thread about valve adjustment (on the Z400) and this made me ask the question; How ...
Old 05-02-2004, 09:37 PM
2fun's Avatar
Super Sonic Moderator
Last Online: 09-07-2010 09:51 AM
Question Valve adjustment on the YFZ 450??
How often do you need to adjust the valves on the YFZ 450??:
Old 05-02-2004, 09:41 PM
MATTXR250R's Avatar
Retired ATMer
Last Online: 08-27-2008 06:35 PM
Default Re: Valve adjustment on the YFZ 450??
I think alot of guys on the YZ450F adjust them every 6 months or so..or check them every 6 months I should say and adjust accordinling...I don't see why the YFZ would be any different...
Old 05-02-2004, 09:47 PM
Woody_YZF's Avatar
www.motorsportsofutah.com
Last Online: 08-27-2010 07:53 PM
I wouldn't touch them unless it's having a hard time with cold starting or are making noise. I haven't adjusted my YFZ that is 10 months old at all and it probably has over 100 hours on it.
Old 05-02-2004, 09:48 PM
2fun's Avatar
Thumbs up Re: Valve adjustment on the YFZ 450??
Cool!
Thanks for the info!!
Old 05-02-2004, 09:49 PM
MATTXR250R's Avatar
Retired ATMer
Well there ya go 2fun...if anyone knows...Woody does.
Old 05-02-2004, 09:50 PM
2fun's Avatar
Right!
Always good to hear from the guys here, and Woody especially since he owns so many!!
Old 05-02-2004, 11:19 PM
hardlydangerous's Avatar
Last Online: 01-09-2009 01:16 AM
Once a year should be fine while you are doing your anual tune up.
Old 05-03-2004, 09:05 AM
Woody_YZF's Avatar
Or he just makes it up. LOL
Old 05-03-2004, 09:37 AM
MATTXR250R's Avatar
Retired ATMer
LOL Woody..I doubt that
Old 05-03-2004, 09:53 AM
2fun's Avatar
Thanks Hardley!
Always good to see you pop in for tech questions!
Woody;
You've already gone there and done that for many aspects (especially on the YFZ), so I trust your opinion on many ATV's.
Old 05-03-2004, 10:05 AM
The better the oil and jetting the longer the valves will stay in adjustment.
I've got over 70,000 km on my VLX and has never needed adjustment since it's original adjustment after break in. I check it every year when I change my coolant and sync my carbs.
I have several friends that have me check there valves every 6 months or year on everything from dirt bikes to ATVs. The only ones that need adjustments are the guys that don't change their oil regularly or can't be bothered use a good synthetic. Or the guys running with the jetting out of wack.
Old 05-03-2004, 10:08 AM
2fun's Avatar
Thanks Bro!
When it actually comes time to adj the valves, I will be asking some questions here as I am a 2-stroke guy, and have never had to perform this task!:
Old 05-03-2004, 10:24 AM
Well don't worry about it , it's an easy job.
Every engine is different but the procedure is always the same.
All you got to do is find TDC on the compression stroke.
Remove the valve adjuster cap on the head and the timing plugs on the engine and rotate the engine until the "T" lines up with the index mark. If either valve is open, rotate the engine until the mark lines up again. (With the engine at TDC on the compression stroke both intake and exhaust valves must all be closed and the rockers loose.
Now find out the specs of intake and exhaust valves, and check that the clearance is ok using a feeler gauge. If it's not simply loosen the lock nut and adjust the rocker so you can feel a slight drag on the feeler gauge. Then tighten the lock nut and move on to the next valve.
The most important thin about the job is, make sure the engine is cold. Let it sit over night and adjust the valves the next day
Just be thankful you don't own a Honda V4 or inline 4. The V4 Magna I just did has 4 valves per cylinder. The inline 4's use special thickness shims that you need to replace for every valve :
Old 05-03-2004, 07:45 PM
2fun's Avatar
Cool!
Thanks again bro!
Old 05-03-2004, 09:21 PM
Woody_YZF's Avatar
Right on. That's excellent information.
Old 11-02-2008, 06:53 AM
Last Online: 11-02-2008 06:53 AM
can one of you guys help me out and give me the specs. i dont have a service manual
Old 11-02-2008, 11:43 PM
2fun's Avatar
Go here and you can download one for yourself.
Old 02-07-2009, 08:35 PM
stillridin's Avatar
Last Online: 01-02-2010 08:51 PM
You've got to be kidding? I thought It was every 50hrs or mabye that was
after the first 50hrs. Anyway, what are some symptoms when it does start to need an adjustment?
Old 02-09-2009, 12:03 AM
2fun's Avatar
If you start hearing noise coming from the valve train, or if it becomes hard to start when cold are a couple of symptoms that your valves may be out of adj.
I checked mine after about a year of use when doing the cam mod, and at that time, they were still ok.
Old 02-13-2009, 07:31 AM
Woody_YZF's Avatar
The YFZ does not need adjustment quite as often as the bike since it doesn't rev quite as high. I think 50 hours is probably sufficient unless symptoms mentioned above show up.
Similar Threads for: Valve adjustment on the YFZ 450??
Valve Adjustment! YFZKID ATV/UTV - Yamaha 5 04-19-2008 09:17 AM
525 exc valve adjustment sledhedz900iq 4-Stroke Motorcycles - KTM 13 05-06-2006 09:40 PM
Valve adjustment & other ?'s TRXman86 ATV/UTV - Honda 13 10-17-2004 09:42 PM
valve adjustment? Riley_400 4-Stroke Motorcycles - KTM 11 03-23-2004 07:23 AM
valve adjustment INsANE_MOTO 4-Stroke Motorcycles - General Discussion 11 02-15-2004 04:18 PM
Powered by vBulletin® Version 3.8.5
Copyright ©2002-2010, JDub Consulting, Inc. All Right Reserved.
