Quantcast raptor 660 chain adjustment problems
This is a discussion on raptor 660 chain adjustment problems within the ATV/UTV - Yamaha forum, part of the ATV/UTV Forums category; i just bought my 2003 raptor 660 and i went to adjust the chain. I loosened the nuts on the ...
Old 10-31-2008, 07:21 PM
Last Online: 10-31-2008 07:22 PM
Default raptor 660 chain adjustment problems
i just bought my 2003 raptor 660 and i went to adjust the chain. I loosened the nuts on the side of the cradle and broke the cradle loose i then tightened the right hand screw then went to the left hand screw and thats where my problem lies. when i went to tighten the bolt it would not move, sprayed wd-40 on it thinking it had mudd in threads, ended up turning 1/2 turn both ways and then would get tight, so tight that the bolt looked to almost break off. I belive the person i bought it from had the bolt out and cross threaded it. what do I do ???? chain makes alot of noise and needs tighened severly
Old 10-31-2008, 10:18 PM
I've been RM-Zedded
Last Online: Today 05:12 PM
I would bet the threads are fine, but that the metals are dis-similar and have corroded together. My suggestion is to apply some heat and see if that helps. I also suggest trying to slowly to get it out. It will break off it you try too hard, as those bolts aren't very tough.
I had this exact problem on my dirt bike. It was a PAIN to fix.
In the end I had to drill it out and use an aftermarket replacement (which sucked).
My guess is you may end up doing the same, only drilling and re-tapping.
I hope you have better luck than I did, and may I suggest applying some anti-seize to those bolts going forward (it's a little tube you can get from any auto-parts store).
Old 11-01-2008, 12:33 PM
2fun's Avatar
Super Sonic Moderator
Last Online: Today 12:29 PM
Thats a good point Woody...
raptor sport:
Are there inserts in the swingarm for the bolts to go into, or is it like Woody suggested (threaded straight into the aluminum swinger).
I looked at the microfische on a parts website but could not tell from the picture. You may not need it since you have the ATV right in front of you, but here it is anyways. You might need it later on for something else. [Only registered and activated users can see links. ]
Old 11-01-2008, 12:34 PM
2fun's Avatar
oh, and welcome to ATM!!!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads for: raptor 660 chain adjustment problems
Proper Chain Adjustment FFRacing11x General Discussion 2 01-10-2008 09:26 PM
Chain adjustment problem Moto man26 2-Stroke Motorcycles - General Discussion 17 07-06-2007 12:09 PM
Chain adjustment on RM80 2 beer 2-Stroke Motorcycles - Suzuki 0 04-11-2007 11:00 PM
Chain Adjustment Moto man26 2-Stroke Motorcycles - General Discussion 4 10-14-2006 08:32 AM
Cam chain adjustment TixiLix 4-Stroke Motorcycles - Honda 27 11-30-2005 07:27 AM
vB.Sponsors
Page generated in 0.15287 seconds with 12 queries
