Piston installation Question
This is a discussion on Piston installation Question within the ATV/UTV - Yamaha forum, part of the ATV/UTV Forums category; I'm currently in the process of installing a cp high compression piston on my YFZ, but I noticed that the ...
Old 06-26-2005, 07:35 PM
Last Online: 01-31-2006 10:41 PM
Default Piston installation Question
I'm currently in the process of installing a cp high compression piston on my YFZ, but I noticed that the circlips that came with it are a little different then stock. Should I use those provided by cp or the stock ones? The cp ones don't have the two holes in them to remove them.
Old 06-26-2005, 09:23 PM
Shocknut's Avatar
Default Re: Piston installation Question
If the pin boss has a relief area (like a 2 stroke piston) that allows you dig them out after installation then use them. If not, I wouldn't use them. You have to be able to get them out, period.
Old 06-26-2005, 09:48 PM
quadfather03's Avatar
Last Online: 01-18-2010 05:28 PM
Never reuse circle clips its a no no to all engine builders if you cant get the new ones to work then i would find a set somewhere but never reuse circle clips. Good luck hope you enjoy the mod.
Old 06-26-2005, 11:49 PM
Last Online: 07-14-2009 12:23 PM
Usually you can use something akin to an icepick whether there are holes or turned in ends to grab. Never had a problem getting them out of anything. If you decide you cant live without the stock type, just make sure they are of the same gauge/thickness etc. Piston suppliers send clips that work and are designed for the grooves on their respective pistons. Take your pick on turning the open ends up or down before putting the cylinder on.
Similar Threads for: Piston installation Question
Question about '03 YZ125 piston kit moto821 2-Stroke Motorcycles - Yamaha 3 04-23-2009 11:09 AM
Cylinder Matching with piston Question Moto man26 2-Stroke Motorcycles - General Discussion 9 01-20-2008 02:28 PM
wiseco piston question YZ125motoracer 2-Stroke Motorcycles - Yamaha 2 03-13-2006 05:24 PM
Vertex piston question KX02 2-Stroke Motorcycles - General Discussion 5 03-31-2005 08:54 AM
RM 250 Piston/Wear Limit Question drman 2-Stroke Motorcycles - Suzuki 13 04-19-2004 07:25 PM
